Play between inboard joint and half shaft 96 accord MT?
Old Oct 30, 2004 | 12:47 PM
flyinga's Avatar
Default Play between inboard joint and half shaft 96 accord MT?
96 accord MT. There is about 1/8 to almost 1/4 inch of play between the half shaft (going to the drivers side wheel) and the fixed-bolted shaft going to tranny. I thought the play was in the CV joint but now after placing the inboard joint on the fixed shaft I found the play seems to be in the splines. (I have the half shaft apart and the inboard joint is separate. Looks like the bearing on the fixed(bolted shaft to tranny) is not loose?
Can the splines wear out? This joint seems to have too much free play. Or is this normal? Car has about 78,000 miles.
wid2001
Jul 18, 2016 05:53 AM
MadVladCivic
Jan 22, 2013 12:02 PM
cycopath
Apr 23, 2008 12:11 PM
flyinga
Jan 6, 2006 10:27 AM
huyvu90
Sep 16, 2004 09:05 PM
