My sisters F22b2 has no spark, Help plz
Old Oct 30, 2004 | 09:15 AM
TeamDOHCside's Avatar
Default My sisters F22b2 has no spark, Help plz
Hey guys my sisters F22b2 has no spark to the coil. i replaced the coil and still nothnig, its something before the coil. Any suggestions? I duno what it is, any of you had the same problems?
Thanks much...
Chase
Old Oct 30, 2004 | 09:48 AM
KatyHonda's Avatar
Default Re: My sisters F22b2 has no spark, Help plz (TeamDOHCside)
Check the Blk/Yel wire to the ignition coil to be sure you're getting power to the coil and check distributor ground (Brn/Blk).
If both of these are OK, the ignitor should be removed and checked at a AZ or other parts outlet.
Make sure the CEL is not delivering a code such as missing TDC/CKP/CYP signal.
If tach is not showing any rpms during cranking, the ignitor is likely.
good luck
Old Oct 30, 2004 | 12:55 PM
Default Re: My sisters F22b2 has no spark, Help plz (KatyHonda)
ok thanks, where is the ignitor located
1992blueGSR
Oct 24, 2008 06:11 PM
nemesis25
Nov 15, 2007 10:27 AM
Accord93SE
Jun 30, 2006 08:12 PM
2000Accord5sp
Nov 17, 2003 11:47 PM
