need info for oil change on my del sol
Old Oct 30, 2004 | 06:28 AM
Slvr_CRX's Avatar
Default need info for oil change on my del sol
have a 95 del sol wanted to know what kind of oil and how much it takes for an oil change? and what filter you guys think i should use thanks.
Old Oct 30, 2004 | 06:31 AM
DemostheneZ's Avatar
Default Re: need info for oil change on my del sol (Slvr_CRX)
what's it say in your owners manual?
Del Sizzle's Avatar
Search oil changes....Archived content. There is alot of info
Old Oct 30, 2004 | 06:35 AM
Slvr_CRX's Avatar
Default Re: need info for oil change on my del sol (DemostheneZ)
i dont have my manual for the car. just got the car of someone
Old Oct 30, 2004 | 09:39 AM
sol2nr's Avatar
your del sol isn't any different than any other honda. and the engine is basically the same as any other economic engine out there. i use mobile 1 synthetic 10w 30 and sometimes 10w40. u could just use a regular honda 10w30 in it. do some searches and you'll find soo much info.
as for the filter....i'd recommend HAMP (Honda AfterMarket Performance) oil filters. there are two sizes, small and large, with the smaller one keeping the pressure about 5 psi higher. these filters aren't that easy to come by, and aren't very cheap, but they are awesome. there are some articles about them on the internet w/ comparisons of HAMP vs regular Honda filters (US, canada, japan) and vs other brands. http://www.prostreetonline.com...eid=2
just buy them in bulk and use at your leisure. inlinefour sells them for 12bucks each but i have paid as low as $7 each shipped (for 10) on another website, can't remember name right now. IPS racing had a h-t special of $6 each for 10or more.
Old Oct 30, 2004 | 09:42 AM
dohcdelsol93's Avatar
Default Re: need info for oil change on my del sol (sol2nr)
put in 4 quarts then check level. Start, run for 1 min, let sit for 5 min. then check level again. I usually end up with 4.25
Old Oct 30, 2004 | 01:54 PM
EK45VTi's Avatar
Default Re: need info for oil change on my del sol (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">put in 4 quarts then check level. Start, run for 1 min, let sit for 5 min. then check level again. I usually end up with 4.25</TD></TR></TABLE>
Correct!!!!
And use Honda OEM oil filter... I think that is the safest way... and the safest way is the BEST way
Old Oct 30, 2004 | 02:00 PM
skip.two's Avatar
about 3.5 - 4 quarts of 10w30 Mobil 1 w/ S2000 filter
you should have Searched this on your own.
splashy
Apr 6, 2015 04:58 PM
Droid407
Jun 23, 2009 05:28 PM
kidwit93delsol
Dec 2, 2007 07:30 PM
Xmar
Sep 11, 2006 08:15 AM
Elwuudz
Jan 15, 2006 10:16 AM
