i have a ? bout HX rims on GSR suspension.so.cal
Old Oct 30, 2004 | 03:15 AM
4drferio's Avatar
Default i have a ? bout HX rims on GSR suspension.so.cal
i have a eg6 rhd ...with GSR calipers
im just curious..y i can fit 14inch blackies steelies..n i CANT fit the HX..there both 14s..but hx wont fit..it goes in but wont move..tires scarp da CALIPERS....whats weird is that..the blackies n the HX are both the same offset..can some please xplain???
Old Oct 30, 2004 | 03:29 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: i have a ? bout HX rims on GSR suspension.so.cal (jdmcivicx08)
the caliper rubs on the spokes of the hx wheels. you either have to shave down the side of the caliper or use wheel spacers if you want to fit hx wheels over gsr brakes.
Old Oct 30, 2004 | 04:16 AM
Ricey McRicerton's Avatar
Default Re: i have a ? bout HX rims on GSR suspension.so.cal (AzntaggeR)
The rims are shaped differently, and it puts the spokes closer to the caliper (as stated above me). Dass why y0!
Old Oct 30, 2004 | 07:45 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
Default Re: i have a ? bout HX rims on GSR suspension.so.cal (Ricey McRicerton)
just god's way of telling you hx wheels sux
Old Oct 30, 2004 | 09:34 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: i have a ? bout HX rims on GSR suspension.so.cal (BrokeAssWhiteboy)
If you want a ghetto way of making that work, put the HX wheels on, drive down the driveway or street for just a little bit, and the calipers will scrape away the part of the wheel that's touching. There'll be little metal shards all over the place, so be prepared to clean up. The other alternative is to dremel the inside of the wheel, which would be cleaner, but would take more time and effort. The way I figure, HX wheels are cheap enough that it doesn't matter if you screw 'em up a bit.
Old Oct 30, 2004 | 06:52 PM
4drferio's Avatar
i put da hx on da front n my car wouldnt move..hah..i waz like fuc..
Old Oct 30, 2004 | 11:50 PM
Suspetise...
You definitely have to give it gas if you want to try that method. Just putting it in drive/1st gear won't do, as there is a bit of resistance.
Old Oct 30, 2004 | 11:55 PM
GaiSensai`'s Avatar
Old Oct 31, 2004 | 01:08 AM
e g - s i x's Avatar
you can also use washers lol
Old Oct 31, 2004 | 01:27 AM
Dengar's Avatar
Default Re: (aznxlunatik)
What is the offset of the hx wheels?
Old Oct 31, 2004 | 01:49 AM
E-brake or Handbrake's Avatar
Default Re: (Dengar)
Yup, the spokes will rub against the caliper. And Yup, you'll have to try either of those two methods as mentioned above. But I'd go with different rims...but that's just me.
Old Nov 1, 2004 | 08:52 AM
ek_b16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">The rims are shaped differently, and it puts the spokes closer to the caliper (as stated above me). Dass why y0!</TD></TR></TABLE>
Thats correct I had to grind down the calipers in order to put my hx rims on.
jsull.
May 15, 2005 12:11 AM
ef8mugen
Aug 16, 2004 11:05 PM
Black R
Jan 29, 2003 05:37 PM
specie
Nov 17, 2002 01:49 PM
airon
May 10, 2002 09:37 PM
