B&M fuel pressure regulator
Old Oct 30, 2004 | 12:25 AM
rac3r's Avatar
Default B&M fuel pressure regulator
hi everyone
need some help on how to adjust my fuel pressure regulator.
I already bought the gauge that goes to the fuel pump
number on the gauge is range from 0 to 60
where should I set it?
I have only bolt on stuff I/H/E walbro 190
thank you in advance
Old Oct 30, 2004 | 12:36 AM
eda6's Avatar
Default Re: B&M fuel pressure regulator (rac3r)
If you got a b16 I'd set it to 44 psi. What motor do you have?
Old Oct 30, 2004 | 06:47 AM
HobbesGSR's Avatar
Measure factory static pressure (w/the vacuum hose off) - and add like 3-5 lbs -- that's about right for intake & exhaust bolt-ons. The only way to really tell is to dyno it and that's not even perfect
Old Oct 30, 2004 | 11:53 PM
rac3r's Avatar
Default Re: B&M fuel pressure regulator (HobbesGSR)
B18C1
Old Oct 31, 2004 | 10:10 AM
cjohnson_2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HobbesGSR &raquo;</TD></TR><TR><TD CLASS="quote">Measure factory static pressure (w/the vacuum hose off) - and add like 3-5 lbs -- that's about right for intake & exhaust bolt-ons. The only way to really tell is to dyno it and that's not even perfect</TD></TR></TABLE>
Thats not true. There are some motors that are happier with a little less fuel pressure. You really dont know till you dyno it. Set it at stock fuel pressure settings.
Old Oct 31, 2004 | 11:27 AM
fkncivic's Avatar
Default Re: B&M fuel pressure regulator (cjohnson_2)
this is a good question.. what is stock fuel pressure settings.
Old Oct 31, 2004 | 11:44 AM
eda6's Avatar
Default Re: B&M fuel pressure regulator (fkncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkncivic &raquo;</TD></TR><TR><TD CLASS="quote">this is a good question.. what is stock fuel pressure settings.</TD></TR></TABLE>
Do a search. 44-46 psi is right for that setup. Dyno it to see exactly where it needs to be.
Old Oct 31, 2004 | 10:11 PM
fkncivic's Avatar
Default Re: B&M fuel pressure regulator (eda6 hatch)
i had an injector fowl out and now i cant seem to get my fuel pressure right.. i have an aem fpr and str rail, walbro 255 and it seems to like to jump back to 60 at idle.. i have nooo clue but i gotta figure it out soon.
Old Nov 2, 2004 | 09:17 AM
HobbesGSR's Avatar
True, often leaning the motor out a tad will increase the performance... you really should dyno the motor, for an exact number. Leaving it at / close to factory would be best for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkncivic &raquo;</TD></TR><TR><TD CLASS="quote">i had an injector fowl out and now i cant seem to get my fuel pressure right.. i have an aem fpr and str rail, walbro 255 and it seems to like to jump back to 60 at idle.. i have nooo clue but i gotta figure it out soon.</TD></TR></TABLE>
???? elaborate?
Old Nov 2, 2004 | 07:30 PM
StorminMatt's Avatar
I should note that leaning can especially help if you have a higher flow fuel pump. Sometimes, higher flow fuel pumps can overwhelm the regulator, bumping up fuel pressure. This especially tends to happen if you get overzealous when upgrading your pump, like if you decide to get a Walbro 255LPH for your bone-stock B16A.
Old Nov 3, 2004 | 09:32 AM
rac3r's Avatar
Default Re: B&M fuel pressure regulator (StorminMatt)
so the best way to know exactly is dyno my car?
do you guys know where a good dyno place is san diego or LA area?
FYI: I put the fuel pressure regulator on 38 psi
do you think is too low?
Old Nov 3, 2004 | 06:05 PM
fkncivic's Avatar
[QUOTE=HobbesGSR]True, often leaning the motor out a tad will increase the performance... you really should dyno the motor, for an exact number. Leaving it at / close to factory would be best for now.
???? elaborate?[/QUOTE
even after i adjust the fp down usiing the guage and the fpr it seems to like to jump back to 60
01_ITR
Jul 15, 2008 09:26 PM
91civichatch2571
Jan 6, 2005 09:15 AM
Muckman
Dec 6, 2003 01:40 PM
TakaIntegra
Jun 18, 2002 06:30 AM
