could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch?
Old Oct 29, 2004 | 10:15 PM
SOHC_Brian's Avatar
Default could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch?
alrite, i just finished searching and seems like noones really sure. some say it'll fit, some say its too short. i want to know from someone that has actually done it, or seen it fit. not i heard it'll fit i'm hitting the junkyard in the morning and i know theres couple 90-93 tegs there, and most likely no 94+.
TIA
Old Oct 30, 2004 | 09:32 AM
dohcdelsol93's Avatar
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (lazyassbrian)
no, you need 94+ shifter linkage, it's different on the 90-93.
Old Oct 30, 2004 | 02:22 PM
b17a1teg's Avatar
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (dohcdelsol93)
Sorry but yes you can use it....I took the shift linkage from my 92GSR and used it on a b16 swap on my friends 92 hatch...bolted up and works like a charm
Old Nov 1, 2004 | 06:21 AM
SOHC_Brian's Avatar
this is what i ran into when going through the search some yes, some no
Old Nov 1, 2004 | 07:36 AM
boosted_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyassbrian &raquo;</TD></TR><TR><TD CLASS="quote">this is what i ran into when going through the search some yes, some no</TD></TR></TABLE>
the only thing i can say is just try it, it only takes like 10 minutes to put it on and see. sorry i cant help more
Landon
Old Nov 1, 2004 | 11:23 AM
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (boosted_dc2)
they are different, held next to one another they have considerable differences other than part numbers. I would buy what you know works.
Old Nov 1, 2004 | 06:59 PM
gutted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17a1teg &raquo;</TD></TR><TR><TD CLASS="quote">Sorry but yes you can use it....I took the shift linkage from my 92GSR and used it on a b16 swap on my friends 92 hatch...bolted up and works like a charm</TD></TR></TABLE>
theres your answer. he did tried it out himself and said it works. hopefully he didnt say it for the hell of it. LOL
Old Nov 2, 2004 | 01:48 AM
ek99's Avatar
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (gutted)
They do look different but it will work. I'm running a 92 shift linkage on my 96 gsr civic. Who ever says it doesn't, obviously never tried it.
Old Nov 27, 2004 | 09:58 PM
SOHC_Brian's Avatar
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (ek99)
i tried it and it works thats what i'm using right now. payed a lot less than what 94+ teg linkages go for
Old Nov 28, 2004 | 08:15 PM
10secwantabe's Avatar
Did you use one from a GSR?
Old Dec 9, 2004 | 07:03 AM
SOHC_Brian's Avatar
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (10secwantabe)
not sure seller didnt say. just said its from a teg
Old Dec 9, 2004 | 12:46 PM
Katman's Avatar
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (b17a1teg)
I agree it will work...
in a reverse fashion my friend used a 94-01 integra shift linkage in a 90-93 integra and it bolted up fine.
Old Dec 9, 2004 | 01:39 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (K@man)
it works, my friend used it on a 92 teg to 92 bubble back
Clipsed
Jan 20, 2009 11:51 AM
stackz
Nov 9, 2006 06:44 AM
redhondacivic
Jan 14, 2006 02:10 AM
Exodus1811
Feb 29, 2004 01:20 AM
rice4life
Aug 28, 2003 06:43 PM
