89 ef blown motor
Old Oct 29, 2004 | 10:00 PM
eggizle's Avatar
Default 89 ef blown motor
blew the stock dx motor in a 88 ef/88 civic hatch. i have a dx motor that came out of a friends stock 92 dx motor out of the eg chassi. now what im trying to say is will everything go in the ef chassi by just swiching the cable tranny and wiring harness over to the 92 dx motor? any help will be appreciated.
Modified by Eggiz at 11:41 PM 10/29/2004
Old Oct 29, 2004 | 10:03 PM
Si_Racer13's Avatar
Default Re: 89 ef blown motor (Eggiz)
you will have to convert to OBD1 but a boomslang harness will take care of that no problem. You will have to also convert your DPFI to MPFI since the EG motors use a fuel rail and 4 injectors.
Old Oct 29, 2004 | 10:16 PM
eggizle's Avatar
so i cant just switch the ob0 harness on to the obd1 harness?
Old Oct 29, 2004 | 10:23 PM
Si_Racer13's Avatar
Default Re: (Eggiz)
no cause it is different from the 4th gen so you will having missing plugs in some spots and extras in others.
Old Oct 29, 2004 | 10:37 PM
I Have an STD's Avatar
wrenchin'
Default Re: (Eggiz)
if you want to just make the car stock again, you just have to swap over the intake manifold, dist, tranny, and harness. if u actually want to make it faster/better, convert to MPFI.
Brett
Old Oct 29, 2004 | 10:41 PM
eggizle's Avatar
thanks brett.
Old Oct 29, 2004 | 10:45 PM
eggizle's Avatar
what all is needed to convert the dpfi, to mpfi?
Old Oct 29, 2004 | 10:48 PM
eggizle's Avatar
never mind found it. but thanks for all the help. greatly appreciated.
4gencivicef9
12
Jul 31, 2006 05:30 PM
crazykid9137
13
Aug 15, 2005 08:00 PM
eggizle
Oct 29, 2004 10:12 PM
pip9
Dec 1, 2003 04:05 AM
