stuck ball joint 00 si
Old Oct 29, 2004 | 05:36 PM
nissanjon's Avatar
Default stuck ball joint 00 si
howdy
i'm trying to pull my motor. i have 3 of the 4 balljoints removed (hammer & fork). The driverside ball joint in the control arm is so stuck that it is ruining my fork.
can anyone tell me how to remove it? please thanks
Old Oct 29, 2004 | 05:40 PM
marshun's Avatar
Default Re: stuck ball joint 00 si (nissanjon)
wack the joint with a hammer. not on the bolt part. just around it. dammit, brain fart, i dont know the name for it.
Old Oct 29, 2004 | 05:53 PM
pdiggitydogg's Avatar
been covered lots of times.
This is what I do (all together):
-Gear puller on the threaded bottom of the joint, pressing it up through the lca.
-OE jack raising the knuckle - putting spring's force on the lca to separate from knuckle.
-4lb sledge beating on the flat area on the lca near the knuckle.
This method has always worked for me.
Old Oct 29, 2004 | 06:32 PM
Redline96LX's Avatar
* B A N N E D *
careful wit that spring. Just a warning, springs have a lot of power coiled up.
DEL HATCH
Dec 16, 2006 01:57 PM
miguelv0723
Nov 11, 2006 04:26 PM
2camsaam
Oct 2, 2003 07:30 AM
civcexcoupeblack
12
Sep 22, 2002 02:27 AM
ScottEK
17
Sep 21, 2002 06:23 PM
