battery keeps dying ! alternator?
Old Oct 29, 2004 | 01:35 PM
B18 CYA's Avatar
Default battery keeps dying ! alternator?
Well, about a week and a half ago my car wouldn't start even though I let it run for a bit...the battery was completely dead. So my friend said to remove the positive wire from the battery and if it still runs, that means the alternator is good. So I was like ok and bought a new battery.
Put the battery in, ran good for about 2 weeks already and now that battery is dead... I can push start the car and it'll run. But when I try and start it, the battery is completely dead. Anyone know what it may be? Anything to test simply? Thanks
Old Oct 29, 2004 | 01:45 PM
msmotorsports's Avatar
Default Re: battery keeps dying ! alternator? (B18 CYA)
Charging system is the culprit. You'll have to check all the charge lines and verify the alternator itself is still good.
Old Oct 29, 2004 | 03:04 PM
HulkSmash's Avatar
you have a short to ground somewhere. check your starter wire. that's the first place i would check.
Old Oct 29, 2004 | 07:59 PM
derekcarr's Avatar
When you go to start the car does the starter make any noise??? What do you hear???
Derek
tomatolord
Jun 14, 2015 02:13 PM
Dontoh
Aug 9, 2011 08:19 PM
tkda
29
May 5, 2009 02:46 PM
Scud
Feb 28, 2008 03:35 PM
tigueremalo
Jan 22, 2007 03:10 PM
