2k idle only when cold
ok sorry guys its another idle question. i searched and found alot of similar posts but none had an answer. so heres my problem. when i start cold it idles at around 2k and drops to normal once warmed up. i tried takeing my fitv off and screwing in the white thingy but it didnt do **** and im not sure what it could be other than the fitv becuase thats the only thing that influences cold starts, right? also once in a while i will get a code 43 that is if i read it right but im pretty sure its 43. thast fuel supply in case your wondering. i head bubbles in my coolant could throw off my fitv, should i drain my coolant? what should i do? anyone who has experianced this or has any clue what it might be then let me know its really becoming a problem.
it didnt idle like that before. it keeps getting worse and worse no matter what the temp. even if its warmer out it still idles high. but if you say so then i guess il just shut up.ty
KimvdLinde
Jun 29, 2013 01:40 PM
supradrifter
Dec 19, 2006 08:43 AM
byronl
Jun 14, 2006 08:26 PM
