ACL bearing B18B=B16?????????
Old Oct 29, 2004 | 12:35 PM
Importracer_001's Avatar
Default ACL bearing B18B=B16?????????
I recently bought a set of ACL bearings for my B16 but I got a Bearingkit for a B18B,A, D16
Can I just use these bearings or do I have to send them back, I'm not from USA and I orded the bearing kit from teh states.
Old Oct 29, 2004 | 01:01 PM
West Werks's Avatar
Default Re: ACL bearing B18B=B16????????? (Importracer_001)
Same thing. You'll be alright. Just make sure to measure everything first.
Old Oct 29, 2004 | 01:04 PM
Default Re: ACL bearing B18B=B16????????? (VenGeanceDrag)
This is the bearing kit I got when I order them
Old Oct 29, 2004 | 03:37 PM
TurbodCX's Avatar
You will be fine. the b16 and the b18a/b use wider bearings than the GSR's
Brian
Old Oct 29, 2004 | 05:03 PM
EX-T's Avatar
Default Re: ACL bearing B18B=B16????????? (TurbodCX)
ACL bearing?
Old Oct 29, 2004 | 06:11 PM
The $hop inc.'s Avatar
ACL part number here
Main bearings B16,B17,B18 # 5M1959
Main bearings B21,F ,H series #5M1937
Main bearings D16 ALL #5M1957
Rod bearings B16A, #4B9641
Rod bearings B18A1 #4B1946
Rod bearings B18C1, 5 #4B1925
Rod Bearings B21,F,h series #4B1936
Rod Bearings D16 ALL #4B1956
Those should work ok just remember to plasti gauge it ...
Old Oct 29, 2004 | 10:09 PM
PHiZ's Avatar
Default Re: ACL bearing B18B=B16????????? (TeamSSR)
Hold on, that box doesn't say B16 anywhere on it.
-PHiZ
Old Oct 29, 2004 | 10:56 PM
1slowcrx's Avatar
Default Re: ACL bearing B18B=B16????????? (PHiZ)
in the parts number,the b16 and 18 are the same main bearing,but how about the rods?
Old Oct 30, 2004 | 12:23 AM
TrnsferErr's Avatar
Default Re: ACL bearing B18B=B16????????? (1slowcrx)
ACL bearings are good. my friend uses them on his motors.
Old Oct 30, 2004 | 09:19 AM
DonF's Avatar
Default Re: ACL bearing B18B=B16????????? (TrnsferErr)
The TW on the box means Thrust Washer. Numbers starting with 4B are rod bearings.
Old Oct 31, 2004 | 10:38 AM
Thanks for the replies guys!
I'll use the bearings and will plastigauge them for sure!
Old Oct 31, 2004 | 11:35 AM
DonF's Avatar
Default Re: (Importracer_001)
What was the number on the rod bearings?
dj-t
Jul 2, 2009 08:48 AM
ek_civic96
Oct 24, 2008 05:40 AM
mrDFWmechanic
Aug 18, 2005 04:36 PM
