Will i damage my transmission if.......
Old Oct 29, 2004 | 08:18 AM
Takashi1978's Avatar
Default Will i damage my transmission if.......
when i bought my car the seller says it has a CTR LSD gearbox.
Since it's expensive to pay someone to take out the drive shaft to see if there really is an lsd in there i just changed the trans oil with 75w90 redline lsd oil.
Will putting in LSD specific trans oil in a non LSD gearbox ruin the thing?
Wht are the ways short of taking out the drive shaft to see if i really have a CTR LSD in there?
Thing is when i drive my friends ITR with same Redline trans oil it shifts like butter! Mine is a little stiff (I have Mugen shifter bushings)
Could it be the heavier oil weight?
Old Oct 29, 2004 | 08:23 AM
cmdr430's Avatar
Default Re: Will i damage my transmission if....... (Takashi1978)
have you driven the car hard around a corner....
i.e. do a hard u turn see if the inside tire spins.....
if it does then you have no lsd....
someone correct me if i am wrong in suggesting this....
it was very obvious in my type r that the lsd was there, and not there in the rsx...
as for the tranny fluid..... honda mtf
Old Oct 29, 2004 | 08:40 AM
nightrider's Avatar
use honda mtf and do a quick search because i'm not too sure of the answer, but it's here FOR SURE.
Old Oct 29, 2004 | 09:02 AM
six_speed's Avatar
~jack up the front of the car
~put the transmission in any gear
~rotate one tire and the other one should spin the opposite direction (in nuetral the tires are independent of each other)
also there should be a visible J4D LSD stamp on the tranny as you stand right infront of the car witht hte hood up.
Old Oct 29, 2004 | 09:32 AM
mikestypeRR's Avatar
Default Re: Will i damage my transmission if....... (nightrider)
its the shifter bushings... take those out and you will see how nice it will shift....
had the same thing on my gs-R.
Old Oct 29, 2004 | 10:55 AM
vtec_5900's Avatar
Default Re: (Humping_dragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon &raquo;</TD></TR><TR><TD CLASS="quote">~jack up the front of the car
So is this method work with any cars with LSD? Becoz I heard some european cars turn their wheel in the same way if the LSD is equipped.
Old Oct 29, 2004 | 11:23 AM
all stock's Avatar
honda mtf should cover all oem lsds. aftermarket is a different story.
then again i was talking to the owner of kaaz and he told me that honda mtf is pretty much thick oil and kaaz gear oil has additives that help longevity of their lsd. i use honda mtf.
Old Oct 29, 2004 | 12:37 PM
six_speed's Avatar
Default Re: (vtec_5900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_5900 &raquo;</TD></TR><TR><TD CLASS="quote">So is this method work with any cars with LSD? Becoz I heard some european cars turn their wheel in the same way if the LSD is equipped. </TD></TR></TABLE>
i'm assuming gear/torsen'helical type lsd only.
viscous is a different story and i have no clue about the clutch type.
Old Oct 29, 2004 | 12:40 PM
Opie's Avatar
MTF=g00d
AFA tranny question, use Mikestyper's method.
Old Oct 29, 2004 | 07:42 PM
Thanx for the reply guys,i will try and borrow a jack from my friend soon to find out.
So just to confirm when i do this test i must put the trans in any gear?
I do have the LSD stamp on my trans.Just that too many people scam nowdays,although it says it has a lsd it dosent mean the previous owner didnt take it out and sell before handing the car to me.
Old Oct 29, 2004 | 07:57 PM
LyL18's Avatar
also there should be a visible J4D LSD stamp on the tranny as you stand right infront of the car witht hte hood up.</TD></TR></TABLE>
Best advice yet.
Old Oct 29, 2004 | 09:35 PM
#1151's Avatar
Old Oct 29, 2004 | 09:48 PM
Beach Accord's Avatar
honda's MTF is a hypoid\mineral type oil....
not sure what that redline is exactly...
stick with the Honda MTF
Old Oct 29, 2004 | 11:14 PM
Chubz's Avatar
Default Re: (Beach Accord)
honda mtf is good, i recently switched to Syncrmesh with Friction modifier and its never shifted better, i dont have that 3rd gear grind anymore
Old Oct 30, 2004 | 03:50 AM
.RJ's Avatar
.RJ
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">MTF=g00d</TD></TR></TABLE>
For street use yes.... anything else, get good fluid. Your 'box will run cooler and you will put less wear on it.
Old Nov 1, 2004 | 03:37 AM
today i finally jacked up the car and put it in gear.
Spin one wheel and the other spins in the opposite direction.
Is it safe to say i have a lsd in the trans?
Old Nov 1, 2004 | 03:53 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
I don't think you have a lsd
In my 240, I turn it one way the other turns in the same direction.
Why don't you just do a burn out with some azenis
if you leave two rice paddies, you got a lsd
lol
Old Nov 1, 2004 | 07:16 AM
RallyRedGT-V6's Avatar
Default Re: Will i damage my transmission if....... (MugenHonda)
in my automatic LS, if i spinned one wheel, the other would move oppositely...
Old Nov 1, 2004 | 07:31 AM
Default Re: Will i damage my transmission if....... (96integra)
Is there a diff between ann ITR and CTR lsd?
Mine is frm a CTR.
Old Nov 1, 2004 | 08:41 AM
six_speed's Avatar
takashi1978 - itr/ctr have the same lsd.
yes you do have lsd.
automatic transmission works differently.
and mugen honda your not making any sense.
Midship
May 25, 2006 11:32 AM
dtran002
Dec 8, 2004 08:23 PM
mafay2
Sep 4, 2003 05:36 PM
mafay2
Sep 4, 2003 02:04 PM
KamikazeTypeR
Sep 4, 2001 05:53 AM
