B16A Jdm swap in my 92 Civic Dx any help??
I jus purchased a 92 dx coupe with a Jdm B16A w/cable tranny in it. The motor is it with new mounts and has new gsr axles I am having trouble with the wiring everything is wired up under the hood but having trouble wiring in the b16 ecu need help with the wiring.....
Well, your '92 should be prewired for vtec, so all you have to do is run the wire for the Knock Sensor.
I cant remember the pin location off the top of my head. Do a search and you will find the info you need.
well if it's a b16a1 you have to change the distributor to a obd1. other than that just run the knock sensor fromt the ecu to the shock tower and then down to the sensor
hitmancivic
Jun 9, 2007 07:13 PM
Honissan
Jul 28, 2004 07:44 PM
B16aCRXSi
Apr 19, 2004 06:39 PM
WIDEB16HATCH
Jun 6, 2003 08:31 AM
