build-up of the accord f22
im going to be rebuilding the f22 engine in my 93 accord wagon pretty soon and im looking for some websites, stores, anything wherei can get performance internals for it. pistons, rods, a cam shaft, valves, valve springs, rockers, etc.
im going to be adding a turbo and i figure with the added boost. i might as well do up the inside of the engine now since it will be out of the car and completely dismantled.
so if anyone has any suggestion, advice or hook-ups on parts, it would be much appreciated.
thanks.
thanks.
I had a 92 Accord with the F22a4. I was all about rebuilding it then i got an Integra. Here are some things i remember. http://www.importperformanceparts.net go there and check it out. They have engine rebuild kits that are decent and about $300. Or you could spend about $900 or something for a more high performance kit. Im pretty sure you can run H23 pistons in it if you wanna bore it out a little. Keep the compression down around 8 like the come stock (8.8:1 i think?). Crankshaft...leave that alone and maybe get it balanced or something, no need for a waste of $800 for a new one. I dunno, check it out and if i remember anything ill let you know! Keep it real with the Accord, i loved mine and too bad it had to go!
