Del Sol Trunk Space
come on now. snowboard won't fit, unless it's made for a little kid.
HOWEVER, i throw skis in my sol all the time. i put the back window down and lay them from the passenger floorboard through the rear window. its works just fine, and even w/ a passenger if its not too long of a trip. snowboard would be a little bulkier though. g-luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">fit it in the passenger seat.</TD></TR></TABLE>
exactly, take your roof off...put some kind of padding on the rear part of the roof bar and lay the snowboard on top of that. or you could lay the seat down as far as you can, roll down the rear window, and let the tip of the board in that area.
i was able to carry alot of things in my del sol.. biggest was prolly my front bumper after it came off on the highway.. with good weather, proper tie downs.. you can stick alot of things outta the top of the sol'
i got two plastic adirondack lawn chairs and a table to go with them into the trunk of my sol. just gotta be creative when loading stuff. i had to hold the trunk down with my jumper cables. but, yea a snowboard should fit in the passenger seat if you roll down the back window, just might have to crank the heat up!
If all else fails, you can just put it in your passenger seat and roll down the back window! I read in some online manual that the Sol trunk is 2 cubic feet smaller than the civic trunk. BTW I love my Sol... Cruising with the top off durring good weather is the ****. Don't listen to all those del sol haters out there... they're just jealous cause they cant take the top off their car and fit it in their trunk! If the one you are looking at is in good condition, you should buy it!
Agreed. I did it twice. I flattened my passenger seat as much as possible and stuck the snowboard as far down under the dash and seatbelted it in. Mine fit w/o having the back windown rolled down. longer boards wont work.
Good Luck!
Good Luck!
I hauled an engine stand in the back of my Sol....just had to tie down the trunk(yea I know, ghetto) I also had to carry my b18 around to and from the machine shop.....but a snow board.....probably not....hehe..good luck...
My board doesn't fit, however it fits fine up front, but the girl friend was a little pissed about having the metal blade 2" from her neck while driving... So we had to take her car.
delsolb18c6
Apr 24, 2010 06:11 PM
93first1
May 5, 2006 09:07 AM
600miles on it and i want something different
