S2000 Antenna Swap Question
My antenna in my 1993 Acura Integra LS 3Door is broken and i want to replace it. I was wondering if the s2000 antenna will fit and if it is possible to do without serious modifications.
Here is what it looks like on a 3rd gen
thanks for the help
thanks for the help
I performed this retrofit a few years ago (albeit without the OEM s2000 "amplifier", just the antenna itself - $25 total for everything including some pre-cut PVC piping to make it fit at an angle)
And...
It looked absolutely perfect, especially on a wingless integra.
But...
The reception was absolute crap.
I picked function over form and threw back in the stock bling bling tower antenna
Maybe that $120 OEM "Amplifier" that goes with the antenna itself (not sure what its called) works, but I'd hate to spend that much and find out it doesn't improve anything. Money better spent elsewhere.
EDIT: Looking back at your real question, yes this will also fit 2nd Generation Integras, i've seen it done and it looks great
And...
It looked absolutely perfect, especially on a wingless integra.But...
The reception was absolute crap.I picked function over form and threw back in the stock bling bling tower antenna
OK the reason were looking into this is because right now our antenna is broke and prolly needs to be completely replaced. Also it isnt getting great reception.
Where did you pick up a stock one?
WHat do you mean it's completely broken? THe mast or the motor? Did you check for power to the motor? You can buy the s2000 shark at a dealer. IF you want to just replace the mast you can buy one on ebay for like 20 bucks. I wouldnt suggest it b/c mine broke again after a month. Or if you want a cheaper alternative.....http://www.locustom.com/frameset/home.htm
http://cgi.ebay.com/ebaymotors...46093
Then just replace the mast. It's really simple. Remember that the teeth face the trunk
