Timing belt help-hail mary pass
Old Oct 28, 2004 | 06:51 PM
sr20jd's Avatar
Default Timing belt help-hail mary pass
my brother is heping his friend change the timing belt on his civic, its a 93 SOHC non-vtec I beleive. Anyways, his friend removed the belt before paint marking the belt against the sprockets. If they get the bottom end to TDC, what should the position of the cam sprocket be?
Any help or links would be much appreciated
thanks,
Jeff
Old Oct 28, 2004 | 07:22 PM
drdisco69's Avatar
Default Re: Timing belt help-hail mary pass (sr20jd)
Make sure up is up, and the little marks on either side of the gear line up with the top of the head. Be careful, if the motor is at TDC, turning the cam can force the valves onto the pistons. Move it a little off TDC, line up the cam, and put it back on.
Old Nov 4, 2004 | 05:49 PM
BiTurboCiv's Avatar
Default Re: Timing belt help-hail mary pass (drdisco69)
put the pulley on, take the last plug out put the dipstick in the hole crank motor tell stick is at the highest point thats TDC, then check pulley should be close
Old Nov 4, 2004 | 07:04 PM
drdisco69's Avatar
Default Re: Timing belt help-hail mary pass (BiTurboCiv)
gravity73
Feb 9, 2014 03:05 PM
giovannie23
Aug 9, 2013 08:30 PM
eg6d15
Jan 7, 2008 01:21 PM
ek4__
Aug 6, 2006 04:40 PM
JONBLAZE55555
Nov 9, 2003 09:28 AM
