coilovers or springs?
Old Oct 28, 2004 | 02:43 PM
Kyles ej1's Avatar
Default coilovers or springs?
im selling my gc coilovers because i could use the money and i havent found time to put them on plus i dont need coilovers cuz i dont plan on lowering it anymore once its done. my question is what would be the best thing to lower with when i sell them? i just want it lowered 2" MAX. i dont want it slammed or tucked or anything like that i just wanna get rid of fender gap.
Old Oct 28, 2004 | 03:03 PM
HATCHingMN's Avatar
Default Re: coilovers or springs? (egcoupe)
dont really matter, its up to you
I'll do GC coilover though.
Old Oct 28, 2004 | 03:07 PM
duh blacksheep's Avatar
Default Re: coilovers or springs? (HATCHingMN)
cut your springs.
Default Re: coilovers or springs? (duh blacksheep)
just kidding, just keep the GC and put them in, you already have them, if you have to...get some cheapy lowering springs like intrax or something
Old Oct 28, 2004 | 03:18 PM
madlion's Avatar
faq intrax
intrax springs suck
the fuc who had the coupe before me had those on. it made the car look real nice and tucked but also it killed the stock struts and created bump steer. also it rubbed the fender walls. id get eibach prokit if you want a suttle not to extreme drop. stay away from intrax
Old Oct 28, 2004 | 03:56 PM
JDMFreak's Avatar
Default Re: coilovers or springs? (madlion)
i recommand eibach sportline, you have your 2" drop but it will be close...or you can go with H&R springs which are a little more aggressive then eibach
Old Oct 28, 2004 | 04:20 PM
Kyles ej1's Avatar
Default Re: coilovers or springs? (JDMFreak)
i know h&r and eibach make good springs but have any of u had any problems with them?
Old Oct 28, 2004 | 04:25 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
progress springs perform extremely well.
HamsterStyle's Avatar
i have h&r springs on my ek hatch, I love them. They ride a million times better than my weapon r coilovers. I think the springs are 2" drop
Old Oct 28, 2004 | 04:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madlion &raquo;</TD></TR><TR><TD CLASS="quote">faq intrax
intrax springs suck
the fuc who had the coupe before me had those on. it made the car look real nice and tucked but also it killed the stock struts and created bump steer. also it rubbed the fender walls. id get eibach prokit if you want a suttle not to extreme drop. stay away from intrax</TD></TR></TABLE>
stock shocks on 2 inch lowering or higher spring rates will prematurely wear out struts, so its not because its "intrax" brand, but it might not be the spring rate you want or the "anti sag" that people car for. Lowering 2 inches will also rub the fender walls. the eibach pro-kit is not a 2 inch lowering spring and will wear out stock struts too.
as far as sportlines go...they are 2 inch lowering springs and are very agressive spring rates. the struts wont even be able to dampen these correctly and will blow out faster than intrax will.
Kyles ej1's Avatar
Default Re: coilovers or springs? (HamsterStyle)
how much do H&R usually run for new?
Old Oct 28, 2004 | 04:43 PM
Kyles ej1's Avatar
how are neuspeed springs?
Old Oct 28, 2004 | 07:01 PM
Kyles ej1's Avatar
up?!?!?!
Old Oct 28, 2004 | 07:12 PM
litterbox's Avatar
I am a (Trial User) Army
Eibach Sportline
Old Oct 28, 2004 | 07:29 PM
CHAMPwhteEK's Avatar
i would advise you just to get coilovers so you can get the exact height you want
Old Nov 1, 2004 | 05:19 AM
gabspeed's Avatar
i have H&R sport drop its 1.75 front and 1.50 is what they claim but it will get lower aprox 2.0 with time ride is only 20% stiffer than stock handles great i have tockicos blues and for intrax its not the springs, if you lower you car 2' or more no matter what springs you use stock struts will blow (they are not desing to go that low) or handle stiffer spring rates for that matter. i would strongly recomend you to get a set of aftermarket struts with your springs if you want a decent ride quality and handling, coilovers will give you more flexibility on height adjustment and better handling but you will have to sacrifice ride quality its going to be stiff so its up to you whatever you like
TheEKcoupe
Suspension & Brakes
21
Dec 28, 2009 09:40 PM
shelbyEK!
Suspension & Brakes
Sep 17, 2009 08:57 AM
96CIVICEX
29
May 13, 2009 10:22 AM
markers
Honda Civic (2006 - 2015)
Jan 30, 2009 07:49 PM
HYREV2NR
May 22, 2003 01:06 PM
