intercooler on ef's
Old Dec 20, 2001 | 03:39 PM
One8Hatch's Avatar
New User
Default intercooler on ef's
for those of you whose boosted, how is your intercooler mounted? does it just hang there from conections of the piping? or did you bolt it somewhere w/ brackets? i have the ww rs kit and im planning on peicing together my own kit, i' dbe nice to have pics of the i/c bolted up to wherever its bolted to. thanks
Old Dec 20, 2001 | 03:41 PM
SiR Kid's Avatar
New User
Default Re: intercooler on ef's (One8Hatch)
Mine's a water to air intercooler under the hood... we made brackets to use stock mounting holes for the battery tray and airbox...
here's an explanatory pic...
Old Dec 20, 2001 | 03:43 PM
One8Hatch's Avatar
New User
whats the diffrance between the a/a ic and the a/w ic? i know one uses water to cool down and the other uses air like a radiator, but are there any benifits to using a air/liquid i/c over a air/air ic? or is it all the same? and what turbo and manafold are you using? do you have any clearance problems w/ you turbo, wastegate and radiator, i've read that the z10 radus bars give you the option of running the eg radiator so wouldnt that free up some clearance? thanks
[Modified by One8Hatch, 12:45 AM 12/21/2001]
Old Dec 20, 2001 | 04:23 PM
SiR Kid's Avatar
New User
I'm using a stock radiator, F-Max manifold, t4/3 hybrid turbo, and we had to notch the webbing on the block to make it all fit.
It's REALLY tight, but it works.
Z-10's are on my wishlist, and I hope to have em by February... Before the track's open so I can tune em a good bit...
W/A intercoolers are a good bit more efficient than same size a/a intercoolers. That's why I went with one, not to mention, I wanted a sleeper
Old Dec 20, 2001 | 11:28 PM
Blown90hatcH's Avatar
I had to ditch my stock bumper support and fab up a little mounting bracket for my IC. I also have the ww kit, but I had to cut it out for optimal cooling capabilities. Here are some pics.
Old Dec 21, 2001 | 04:32 AM
CWBETB's Avatar
Default Re: intercooler on ef's (Blown90hatcH)
Blown90hatcH you need a bigger intercooler
I have no intercooler I might be lookng into one of those side mount jobs this summer.
Old Dec 21, 2001 | 05:02 AM
Doodoo's Avatar
Mine is bolted to either side of where the A/C condensor used to be. The guy who did it fabbed some brackets and welded them on.
Old Dec 21, 2001 | 07:23 AM
rainforest's Avatar
Default Re: intercooler on ef's (Doodoo)
man skylinecore is the ****!!!!!
Old Dec 21, 2001 | 09:05 AM
Speed PHreak's Avatar
Default Re: intercooler on ef's (rainforest)
Shitty picture.....but you get the idea. sleeper is good!
Old Dec 23, 2001 | 01:19 PM
civbeater90's Avatar
Default Re: intercooler on ef's (SiR Kid)
how much power are you putting down? just curious to know if the size intercooler you are using can handle high boost duties?
miketurbohonda
Aug 14, 2007 01:14 AM
dohcdelsol
Feb 8, 2004 10:09 AM
hanson said
Apr 30, 2003 02:37 PM
vtec.dc2
Dec 23, 2002 07:58 PM
TurbothisLS
Jun 14, 2002 02:02 PM
