piece of plastic got stuck in throttle plate while driving...scary.......help identify
Old Oct 28, 2004 | 01:24 PM
shorty's Avatar
Default piece of plastic got stuck in throttle plate while driving...scary.......help identify
ok so im drivin just chillin, goin about 35-40mph and i let go of the gas pedal and my RPM's don't drop.. (u know how in automatics sometimes it takes a second for the gear to change) so i wasnt too concern, until the RPM's started going higher and higher... im like WTF is my cruise control on and im hitting somthing??? somewhat in a panic and confused i stick the car in neutral... bad mistake... the car goes all the way up to redline... im like FKKK so i shut the car down and manage to pull over - turn the car back on.. same thing goes straight to redline... so i pop my hood and everything looks cool.... the throttle cable looks like its closed... so i turn on the car and everything runs fine... i cautiously drive a little more and it does the same thing... so this time when i pull over i pop open my intake tube and find this stuck inside my throttle plate.
so my question is... wtf is this piece of plastic, is this somthing that came from my engine bay, or sucked up off the road?? i dont know how the hell it got in there, my intake is stock, everything is stock.... the ONLY thing i can think of, is that a couple of days ago i changed my headlight bulbs and had to remove my intake box in order to reach the wires... where the hell did this thing come from?
Old Oct 28, 2004 | 01:33 PM
shorty's Avatar
Default Re: piece of plastic got stuck in throttle plate while driving...scary.......help identify (shorty)
damn H-T i thought we were quicker then this.... 10 min w/o a response?
Old Oct 28, 2004 | 01:41 PM
JimBlake's Avatar
LOL - read it! "remove for side terminal connection". It came from a battery.
The real question is how did it get thru your air filter??
Old Oct 28, 2004 | 01:49 PM
FormulaGSR's Avatar
Default Re: piece of plastic got stuck in throttle plate while driving...scary.......help identify (JimBlake
and its for a side terminal battery which you shouldnt have
Old Oct 28, 2004 | 01:56 PM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
my optima battery has top and side mount connection points
Old Oct 28, 2004 | 01:58 PM
EJ1 wilcox's Avatar
At least you did the smart thing and turned your car off before you blew your engine and were in a heap of ****...
How did that thing get in there?
Old Oct 28, 2004 | 05:43 PM
shorty's Avatar
ahh the battery... **** im stupid, the battery is right next to the airbox i should have guessed there first.
yeah i guess it got in there when i took my intake box off so i could change my headlights.... pfft im such a moron, **** im lucky that thing didnt get through the throttle body and like into my cylinders or somthing...
does plastic help compression... lol
Old Oct 28, 2004 | 06:03 PM
mr.beeks's Avatar
Default Re: (shorty)
dont worry it happens to the best of us also...
HGZ
May 4, 2013 11:32 AM
curtie94
Mar 26, 2012 02:26 PM
F20B_accord
Feb 19, 2011 07:26 AM
fatpride111
Dec 5, 2008 05:57 AM
lilxvtecxpwr
Oct 25, 2002 03:46 PM
