Purchasing 5th gen Prelude: no clue what owner has done before....
Old Oct 28, 2004 | 12:42 PM
JDM00SI's Avatar
Default Purchasing 5th gen Prelude: no clue what owner has done before....
k I'm purchasing a 5th gen prelude, 97-99 looking in the 80k milage range. i know when i purchase it i will need to change timing belt, change oil, tranny fluid, power steering fluild, what else do i need to do to make sure i take care of it right? also....how much would a shop charge to change timing belt and tranny fluid? thanks
Old Oct 28, 2004 | 12:46 PM
JDM00SI's Avatar
Default Re: Purchasing 5th gen Prelude: no clue what owner has done before.... (bigbeasta4)
bump
Old Oct 28, 2004 | 01:50 PM
PrettyLude's Avatar
normal price to do a timing belt job is aroune 350
Old Oct 28, 2004 | 04:12 PM
drdisco69's Avatar
Default Re: (PrettyLude)
Look on the back bumper for oil grime. Some of the 97 and 98s had a little ring problem...
Old Oct 28, 2004 | 05:53 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">normal price to do a timing belt job is aroune 350</TD></TR></TABLE>
Not on a H22 if it's done right. By right I mean replace the water pump, tensioner pulley, autotensioner unit, timing belt, and balance shaft belt. Expect around $700-$900.
Do not even consider an automatic. The MH6A trans is junk.
Check for smooth shifting into 5th at 70mph plus, and make sure reverse drops in smoothly.
Old Oct 28, 2004 | 07:00 PM
JDM00SI's Avatar
Default Re: (Jim Truett)
of course not automatic lol...also the dip stick..how do i know if the oil is good or not? what color should the oil be? thanks
Old Oct 28, 2004 | 07:10 PM
drdisco69's Avatar
Default Re: (bigbeasta4)
Look under the oil cap. If there is crap built up on it, run. A little is ok, but black **** everywhere is a sign that the oil wasn't changed as often as it should have been.
Old Oct 28, 2004 | 07:35 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbeasta4 &raquo;</TD></TR><TR><TD CLASS="quote">of course not automatic lol...</TD></TR></TABLE>
CYA and double check the VIN number. Many of the base automatics have been converted to manual. I know, I've done it.
Old Oct 28, 2004 | 08:09 PM
JDM00SI's Avatar
how do u know if its been converted? thanks
Old Oct 28, 2004 | 09:38 PM
JDM00SI's Avatar
anyone else w/ advise? thanks
Old Oct 29, 2004 | 03:47 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbeasta4 &raquo;</TD></TR><TR><TD CLASS="quote">how do u know if its been converted? thanks</TD></TR></TABLE>
By checking the 7th digit of the VIN number. A 1 in the 7th place is a 5 speed manual, a 2 would indicate automatic.
RobTurbo
Honda CR-V & Element
Apr 21, 2018 03:59 PM
batlground1
Oct 16, 2006 02:21 PM
HuKaShI
Dec 1, 2003 12:14 PM
Jeff99Base
Sep 7, 2003 07:50 AM
Mover
Sep 16, 2002 07:55 PM
