crx handle like s2000
Old Oct 28, 2004 | 10:59 AM
vvtli78k's Avatar
Default crx handle like s2000
how do i make my 91 crx si handle handle better. it is completely stock. i also own a s2000, now i know it can't come close to that but i want it better than what it is,
any suggestions?
Old Oct 28, 2004 | 11:02 AM
eLUDEnu
Guest
Posts: n/a
Default Re: crx handle like s2000 (vvtli78k)
full tein coilover suspension. energy suspension master kit, some good wheels and tires, and really good swaybars, thats the only way I see you coming close
Old Oct 28, 2004 | 11:05 AM
travis's Avatar
Default Re: crx handle like s2000 (eLUDEnu)
"handle like S2000?"
Start with a RWD conversion.
Old Oct 28, 2004 | 11:06 AM
vvtli78k's Avatar
what kinda sway bars?what is a energy suspension master kit?
Old Oct 28, 2004 | 11:15 AM
sir91's Avatar
I recommed ST's sway bars. The energy suspension master kit is to change all the rubber bushings to urethane. I can get you both items if you like. I can get you the full Tein suspension also or get you Tokico 5-way adjustables and eibach springs. The Tokico's with sway bars and bushings make your car handle really good.
Old Oct 28, 2004 | 11:22 AM
vvtli78k's Avatar
Default Re: crx handle like s2000 (sir91)
is that the brand st?
Old Oct 28, 2004 | 11:23 AM
vvtli78k's Avatar
as for wheels i was lookin at the integra fat fives or the 99-00 si wheels with some falken azenis
Old Oct 28, 2004 | 11:27 AM
eLUDEnu
Guest
Posts: n/a
your gonna need a little wider wheels but those are good tires to start with
Old Oct 28, 2004 | 11:31 AM
vvtli78k's Avatar
the size is 205/50/15 on the azenis
what kinda turbo set up u goin with ? are you stock on the motor?
Old Oct 28, 2004 | 12:40 PM
vvtli78k's Avatar
st , is this a brand of sway bars?
Old Oct 28, 2004 | 12:52 PM
fireant's Avatar
st is short for suspesion techniques... a brand of swaybars.
Old Oct 28, 2004 | 12:53 PM
rice_classic's Avatar
Once you have it set right, the crx should handle BETTER then the s2000 considering that you can get fairly fat tires under it and it's a very light car.
A lot of the time, a 2000 lb car will out handle a 2600 lb car. (all things being equal)
Old Oct 28, 2004 | 01:08 PM
NikoZai's Avatar
jimfab crossmember helps tons, lower rear sway, full cage
Old Oct 28, 2004 | 01:20 PM
eLUDEnu
Guest
Posts: n/a
Default Re: crx handle like s2000 (NikoZai)
junkyard turbo
Old Oct 28, 2004 | 02:10 PM
sit220's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLUDEnu &raquo;</TD></TR><TR><TD CLASS="quote">junkyard turbo</TD></TR></TABLE>
wtf
Old Oct 28, 2004 | 02:12 PM
onePOINTsix's Avatar
handle like a S2K huh, well i'd say get some Tockio 5-ways or Koni yellows, then springs like neuspeed sports or H&R sports, a ST rear sway, Energy suspention master kit and a LSD. The LSD will help alot with underspeer. Also some fatty 15s
Old Oct 28, 2004 | 02:53 PM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: crx handle like s2000 (sit220)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sit220 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf </TD></TR></TABLE>
You must not be with it! get with it man!
props on doing the HMT turbo
Old Oct 28, 2004 | 03:40 PM
SuperSteve737's Avatar
Default Re: crx handle like s2000 (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">Once you have it set right, the crx should handle BETTER then the s2000 considering that you can get fairly fat tires under it and it's a very light car.
A lot of the time, a 2000 lb car will out handle a 2600 lb car. (all things being equal)</TD></TR></TABLE>
That's what I was thinking.
murderedrsx
14
Feb 22, 2010 12:11 PM
Azcheron
Honda S2000
Nov 28, 2006 07:47 PM
JdmLude04
Honda S2000
33
Oct 21, 2004 04:00 PM
LsPower
Honda S2000
Feb 24, 2003 08:25 PM
