(I searched) 95 si mc, booster, and 4040 prop valve
I searched and came up with nothing. I took my buddys mc, brake booster, and 4040 prop valve of his 95 si hatch. They are all in working condition but my question is: the booster and mc will fit if i am correct, but would there be any reason to put on the prop valve even though i still have rear drum brakes. I plan on doing the rear disk swap soon but would it serve any purpose or make any difference in braking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">that prop valve would be a pita to install.. i think the lines are in a different spot?
either way, not worth it cuz u got read drums, it'll make braking WORSE</TD></TR></TABLE>
4040 valve fits perfectly into a ed/ef. Lines are in the same spot. Not too hard to install.
Don't use the valve until you install the rear discs.
951BRO
36
Jun 14, 2007 08:38 PM
crexer
Aug 17, 2004 05:26 AM
crexer
10
Apr 17, 2004 09:13 PM
slut
Oct 23, 2003 11:32 AM
