Turbo or all Motor?
Old Oct 28, 2004 | 07:54 AM
99exd16y8's Avatar
Default Turbo or all Motor?
I have a 99 ex with the d16y8 with the usually mods full intake system, header, catback, vtec controller, etc. I was wondering would it be cheaper in the long run to go all motor or put a small t-25 turbo on and run like 8 pounds of boost with out blowing anything.
Old Oct 28, 2004 | 07:58 AM
Nikos's Avatar
Default Re: Turbo or all Motor? (99exd16y8)
on a d16, I would say turbo
Old Oct 28, 2004 | 08:06 AM
BrianDelSol's Avatar
Default Re: Turbo or all Motor? (Nikos)
D16 = turbo to gain the best power.
Old Oct 28, 2004 | 08:08 AM
Ricey McRicerton's Avatar
Default Re: Turbo or all Motor? (BrianDelSol)
FI is the only way to go on a D series motor. I've had mulitple turbo setups and multiple NA setups, and turbo is much more satisfying. Cheaper to go faster as well.
si_hatch's Avatar
Turbo
ITRacer121's Avatar
Depends on what you use the car for?
Old Oct 28, 2004 | 08:09 AM
Spade's Avatar
Default Re: (ITRacer121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 &raquo;</TD></TR><TR><TD CLASS="quote">Depends on what you use the car for?</TD></TR></TABLE>
True, however N/A is very expensive on a D series.
Old Oct 28, 2004 | 08:10 AM
litterbox's Avatar
I am a (Trial User) Army
I really don't think it does in this case. Turbo will be cheaper than truly going all motor, and you'll get a much more powerful engine. You'll be able to use it as a daily driver, track or strip car too.
Old Oct 28, 2004 | 08:11 AM
99exd16y8's Avatar
Default Re: (Spade)
some sugested turbos t-25 14b????????
Default Re: (99exd16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99exd16y8 &raquo;</TD></TR><TR><TD CLASS="quote">some sugested turbos t-25 14b????????</TD></TR></TABLE>
Greddy 15g kit. I have it and like it. Great for a daily driver and occasional track *****.
EDIT: And this is on my daily driver with about 130k that gets between 16-18k a year put on it.
Old Oct 28, 2004 | 08:15 AM
blackcivic44's Avatar
Default Re: (Ricey McRicerton)
t3 .48/.60
Old Oct 28, 2004 | 02:18 PM
Kirmit D Frog's Avatar
Dog go turbo you can go turbo for about $500 to $1000 if you use DSM parts use the 2gen blow off and any t25 make sure there is not a lot of play in the turbo shaft and then you just need a honda hx manifold and a fmu and a little odds and ends but in the end it will be bad *** "I have ran 20 psi on a sohc d16z6 for about 12 weeks let me tell you that **** is fast&gt;
Old Oct 28, 2004 | 02:19 PM
Default Re: Turbo or all Motor? (Kirmit D Frog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kirmit D Frog &raquo;</TD></TR><TR><TD CLASS="quote">I have ran 20 psi on a sohc d16z6 for about 12 weeks let me tell you that **** is fast&gt;</TD></TR></TABLE>
You won't keep running 20psi for long....
Old Oct 28, 2004 | 02:29 PM
ejONE.mike's Avatar
Default Re: Turbo or all Motor? (Ricey McRicerton)
turbo is best for a sohc and is cheaper
Old Oct 28, 2004 | 02:41 PM
CivicFreak's Avatar
Man, all motor on D series won't get you anywhere, TURBO that biatchhhh. lol
Old Oct 28, 2004 | 02:55 PM
Blazin Civic's Avatar
Default Re: Turbo or all Motor? (CivicFreak)
B series or D series you need a turbo to go fast IMO. Don't know any all motor B or D series cars that are streetable that can run with a car that is actually fast.
Old Oct 28, 2004 | 02:59 PM
PLAN:B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kirmit D Frog &raquo;</TD></TR><TR><TD CLASS="quote"> ...I have ran 20 psi on a sohc d16z6 for about 12 weeks let me tell you that **** is fast&gt;</TD></TR></TABLE>
Damn bro. I would take it down a notch. Goodluck
Old Oct 28, 2004 | 03:38 PM
BlackRocket's Avatar
Turbo!!
Old Oct 28, 2004 | 03:43 PM
Civicse's Avatar
who knows what turbo setup would b best for a d16y7? i've found some nice ones from turonetics but there like 3 grand.
Old Oct 28, 2004 | 03:44 PM
david_rg79's Avatar
Default Re: Turbo or all Motor? (PLANBmotorsports)
explain to me why he cannot run 20psi...is it becasue of sleve movemnet or just u think he will kill the rings or what????
I have read that the sleves are very strong on these motors...i only let the kids out here push 12psi on pumpgass...they all have large 16g's and one kid has been pushing 19psi(his own choise) for a long *** time...we use propane injection to fuel these cars and get ride of detonation...they seem to have no probs
why do you guys say he cant do 20psi???
I have noticed that alot of people on this board say stuff with haveing no experiance of evidence to back up their statments
Old Oct 28, 2004 | 03:52 PM
pink hatchy's Avatar
Default Re: Turbo or all Motor? (david_rg79)
yea, go turbo!! im gonna turbo my car!!!
Old Oct 28, 2004 | 03:54 PM
Doostur's Avatar
i was in the same boat, i swapped in an ls, and now im boostin it.. then i called it a day
Old Oct 28, 2004 | 04:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david_rg79 &raquo;</TD></TR><TR><TD CLASS="quote">explain to me why he cannot run 20psi...is it becasue of sleve movemnet or just u think he will kill the rings or what????
I have noticed that alot of people on this board say stuff with haveing no experiance of evidence to back up their statments</TD></TR></TABLE>
Ever opened a D series motor? The rods are tiny. I'm AMAZED that he hasn't managed to snap a rod or a rod bolt yet. I boost all day every day at 8 psi on a stock D16y7 and would like to know what clutch he runs. What experience do you have to prove that 20 psi is safe?
Old Oct 28, 2004 | 04:15 PM
20 psi aint safe on a b-series motor or pretty much any stock motor for that matter
Old Oct 28, 2004 | 04:18 PM
Civicse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Ever opened a D series motor? The rods are tiny. I'm AMAZED that he hasn't managed to snap a rod or a rod bolt yet. I boost all day every day at 8 psi on a stock D16y7 and would like to know what clutch he runs. What experience do you have to prove that 20 psi is safe? </TD></TR></TABLE>
what kind of turbo kit r u running? i also have a y7 and i'm looking into purchasing a turbo setup
