b16 obd0 using a obd2a (96dx) using a obd1 ecu wiring
Old Oct 28, 2004 | 02:03 AM
turbo_civic_ek's Avatar
Default b16 obd0 using a obd2a (96dx) using a obd1 ecu wiring
any one know how to do this wiring. i have a obd0 b16 motor and a 96 dx hatch. I was told to use the hatch wiring wich is the obd2a and to convert it to use the obd1 hondata ecu. how do i do this?? the hondata already has a conversion harness from obd2a to 1 built in and i have an extra obd1 distributor cause i heard that i'd need that distributor....but what about my injectors and all the other sensors?? i mean the ecu side seems to be already done, but what do i do with the sensor plugs and how do i convert all that?
any help will be appreciated....thanks.
Old Oct 28, 2004 | 02:16 AM
poison's Avatar
Default Re: b16 obd0 using a obd2a (96dx) using a obd1 ecu wiring (turbo_civic_ek)
You`ll need to cut off the injector clips and use the OBD2 plugs, along with the OBD2 injectors.
Wakeboarder482
Aug 22, 2015 02:40 PM
Xathine
May 5, 2013 08:51 PM
tsr2
14
Dec 2, 2006 10:23 AM
Glen Tennis
Dec 17, 2003 06:06 AM
crx1856
May 31, 2003 09:45 AM
