What ecu's can I use
Old Oct 28, 2004 | 01:00 AM
SandFireTypeR's Avatar
Default What ecu's can I use
As I said in my other post, I recently did an automatic to manual transmission swap and i need too swap out the ecu so no more trouble codes will be sent since i no longer have an automatic. I have a civic ex 99 sohc v-tec. So will any p2p (96-00) ecu's work just fine and are there any differences between the years? thanx
Old Oct 28, 2004 | 01:10 AM
Kusai.Nihonjin.Desu's Avatar
Default Re: What ecu's can I use (SandFireTypeR)
so long as it's an obdII.
you could even use an ECU out of an HX, but your car will no likey.
i ran a vx ecu on my d16z6 on my old hatch for about 2 weeks, it was horrible. horrible i tell you.
Old Oct 28, 2004 | 02:19 AM
poison's Avatar
Yes, OBD2a and OBD2b. You need a 99-00 P2P EX ecu. Otherwise you'll need a jumper harness.
Old Oct 28, 2004 | 03:19 AM
murmur9's Avatar
Default Re: What ecu's can I use (poison)
i know im thread horing or whatever...but check out my sig. get a p2p
if it were before 96 , you could just take off a jumper, add a few resistors...and you have a manual/automatic ECU...but not on obd2. good luck ...
Old Oct 28, 2004 | 04:31 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: What ecu's can I use (Nihonjin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihonjin &raquo;</TD></TR><TR><TD CLASS="quote">i ran a vx ecu on my d16z6 on my old hatch for about 2 weeks, it was horrible. horrible i tell you.</TD></TR></TABLE>
you think thats bad.. hahaha, i turbo'ed my VX hatch, on the P07 ECU.. hahaha (check my sig.)
Lildj2983
Oct 30, 2014 10:54 AM
IntegraCF21
Oct 9, 2011 04:22 PM
faxshatch
Mar 18, 2008 05:08 PM
ebp_dc2
Jan 7, 2007 12:04 PM
igo4bmx
Mar 25, 2004 03:56 PM
