white smoke comming out of valve cover
Old Oct 28, 2004 | 12:28 AM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
Default white smoke comming out of valve cover
after driving 4 awhile i opened the oil cap and white smoke started to come out.. what are the causes of this?? i heard it could be piston rings anyone else have any ideas? thanks
Old Oct 28, 2004 | 03:47 AM
DontBlink's Avatar
Default Re: white smoke comming out of valve cover (HONDA_BIGBLOCK)
broken ring lands is my guess.
Old Oct 28, 2004 | 03:50 AM
krshultz's Avatar
I've always thought white smoke == coolant. Blown headgasket?
Were you on a racetrack and it started doing this?
IBTL.
Old Oct 28, 2004 | 11:59 AM
aaaabbbb's Avatar
Default Re: white smoke comming out of valve cover (krshultz)
its not overheating or anything.. it just smoke comming out of the valve cover. i just changed the head gasket too... damn i hope its nothing serious
Old Nov 3, 2004 | 04:04 PM
Rodzknight's Avatar
WELL this is how you really tell what it is, turn the car and and let it warm up. Then check the breather or oil cap for smoke and at the same time lift up the oil dip stick and see if theres any smoke comming off of there, and if theres smoke you fried your rings and that could or should i say will cause blow by.
Old Nov 3, 2004 | 04:56 PM
drdisco69's Avatar
Default Re: white smoke comming out of valve cover (Rodzknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodzknight &raquo;</TD></TR><TR><TD CLASS="quote">lift up the oil dip stick and see if theres any smoke comming off of there</TD></TR></TABLE>
A leakdown test will also tell you where it's coming from.
Old Nov 3, 2004 | 07:23 PM
anothersickhatch's Avatar
Default Re: white smoke comming out of valve cover (drdisco69)
you need to remember that all hondas create blow-by, hence the purpose of a pcv valve. depending on how much blow-by it actually is and how your car is running, it could just be normal.
do a compression test or a leakdown test...that should tell you.
codyweiss97
Mar 8, 2014 11:04 AM
cars101
20
May 6, 2007 02:38 PM
ck123
12
Jul 21, 2006 07:57 AM
SSR'd
Feb 8, 2004 05:46 AM
NeXtLeVeL_TyPe_R
May 16, 2002 06:19 PM
