H22 Swap/Heater Doesn't Work..
Old Oct 28, 2004 | 12:22 AM
mdj_ge's Avatar
Default H22 Swap/Heater Doesn't Work..
help me out... i did a H22 swap and then the heater doesn't come on anymore.
Old Oct 28, 2004 | 02:02 AM
poison's Avatar
Default Re: H22 Swap/Heater Doesn't Work.. (yangja)
Check the fuses. And you connected the heater core lines, correct?
Old Oct 28, 2004 | 04:56 AM
Adam.'s Avatar
Default Re: H22 Swap/Heater Doesn't Work.. (poison)
Probably have the lines not connected correctly, check them.
Old Oct 28, 2004 | 08:04 AM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote">
help me out... i did a H22 swap and then the heater doesn't come on anymore.</TD></TR></TABLE>you did a swap and you cant figure this out? also you need to clear up your question.
Old Oct 28, 2004 | 02:41 PM
Turbogixxer's Avatar
Default Re: H22 Swap/Heater Doesn't Work.. (fastwanabe)
Check the Black valve by the rear mount. check to see if it is not broken and/or the cable is hooked up to it.
Old Oct 28, 2004 | 06:47 PM
AzNpRiD3's Avatar
Default Re: H22 Swap/Heater Doesn't Work.. (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Check the Black valve by the rear mount. check to see if it is not broken and/or the cable is hooked up to it.</TD></TR></TABLE>
yea check that and make sure it is hooked up...its right under the throttle body. I had the same problem after i did my swap and just went to the junkyard and got a new one.
Old Oct 29, 2004 | 02:43 AM
WrongWD's Avatar
is the fan not turning on, or is it turning on but just blowing room temp air?
Deacatur Racer
Dec 9, 2007 12:04 PM
EkPudge
Jul 9, 2006 03:59 PM
killablaze
Nov 24, 2004 02:53 PM
jonjon149
Apr 14, 2004 05:16 PM
uNbrokeN
Jan 28, 2004 09:05 PM
