Honda S2000 Honda S2000
i need main bolts torque specs for F20C
Old Oct 27, 2004 | 10:30 PM
TRAN's Avatar
Default i need main bolts torque specs for F20C
i need main bolts torque specs for F20C.
thanks
Old Oct 28, 2004 | 07:21 AM
GChambers's Avatar
Default Re: i need main bolts torque specs for F20C (Zigga)
Get a shop manual. It has EVERY torque spec. I do not have mine in front of me. If you don't have them by tonight, I will look it up for you.
Old Nov 3, 2004 | 08:34 PM
TRAN's Avatar
Default Re: i need main bolts torque specs for F20C (GChambers)
I'm still looking for torque spec. thanks
Old Nov 4, 2004 | 05:03 AM
edd001's Avatar
when you say main bolts do you mean the head bolts.
Old Nov 4, 2004 | 08:56 AM
doublej's Avatar
pm me a fax number and I will copy the page out of my shop manual.
Jim
Old Nov 4, 2004 | 08:59 AM
WowOzYouRock's Avatar
Default Re: i need main bolts torque specs for F20C (doublej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublej &raquo;</TD></TR><TR><TD CLASS="quote">pm me a fax number and I will copy the page out of my shop manual.
Jim</TD></TR></TABLE>
WTF? just give him the number(s) ... y go all that hastle if you can give it to him right MEOW .....
Old Nov 5, 2004 | 10:09 AM
edd001's Avatar
Default Re: i need main bolts torque specs for F20C (Y2K_S2K)
if it is the head bolts you are on about then it is 22lbf/ft then if useing the old bolts you turn each bolt by another 90 degrees twice but if new bolts then turn each bolt 90 degrees 3 times.
Old Nov 5, 2004 | 01:13 PM
Its_real&its_spectacular's Avatar
New User
Default Re: i need main bolts torque specs for F20C (edd001)
Torque spec for the lower block to the upper block is as follows... 22lb/ft in sequence (from the centre out) then an additional sixty degrees (get a proper torque angle gauge for this...)
Then tighten the 8mm bolts in sequence (also from the centre out) to 16lb/ft
I assume this is what you mean by main... Main bearings...
hondamark35
Aug 28, 2008 01:55 PM
eortizr
Aug 23, 2005 10:08 PM
Archidictus
Nov 26, 2004 03:15 PM
anothersickhatch
12
Jun 10, 2004 02:26 PM
fso_BamBam
May 7, 2004 11:53 PM
