Which size flare end wrench for fuel filter?
I'm about to change the fuel filter in the engine compartment. I've searched and don't seemed to find a thread that addresses to this particular question that I have.
The reason I'm asking is because the flare wrenches I saw in Kragen are sold individually, I can't afford a complete set.
Helms says that I need a 12mm for the banjo bolt. Does it means that I need a 12mm flare end wrench? Or do I use that wrench on some other bolt while removing the fuel filter?
Just wanna make sure I have the right tool before I begin. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShad0w »</TD></TR><TR><TD CLASS="quote">the top bolt is 12 mm, and the entire banjo fitting screw is 17mm.
Yea I just did my fuel filter I was having a hell of a time getting that banjo bolt lose. I had to impact it off lol. 250 ft lb ownage. And you just need a 10 or 12 mm wrench(forget the size) and an adjustable wrench to hold the filter while you loosen it.
randyklimek
Oct 17, 2004 11:37 AM
