96-98 civic radiator support!
Old Oct 27, 2004 | 03:53 PM
akteamster's Avatar
Default 96-98 civic radiator support!
how do i remove the radiator support from my 96 civic...is it easy to do urself or better to do it to a mechanic shop.....i want to remove it and put on a 99-00 support.
i searched for a how too or any info nothing really came up.
Old Oct 27, 2004 | 04:08 PM
son of light's Avatar
Default Re: 96-98 civic radiator support! (akteamster)
Im not positive on the EK, but today I removed the radiator support on my EG that is welded on... Be prepared to do some significant cutting with a air chisel/hammer. This would not be possible without the air chisel. In all honesty, I would have a shop do it, after all the work I did today.
Old Oct 27, 2004 | 06:25 PM
JCritt's Avatar
Default Re: 96-98 civic radiator support! (son of light)
I hear its quite the biyach to get off. Ur doing a 99-00 front end? You can just put it on without removing ur rad support...
Old Oct 27, 2004 | 07:00 PM
akteamster's Avatar
Default Re: 96-98 civic radiator support! (khaa)
YEAH IM DOING THE 99 FRONT END, BUT I WANT IT TOO LOOK CRISPY SO I WANT TO CHANGE THE RADIATOR SUPPORT TOO.
Old Oct 27, 2004 | 11:07 PM
bananaek's Avatar
the core supports are almost the same. you have to either cut off or drill holes on the upper mounting tabs where the bumper uses the plastic pop in screws. everything well bolt on!
RevrsOne
10
Aug 7, 2012 07:27 PM
Panda hatch
Feb 7, 2007 05:58 PM
jdmekB18C
10
May 23, 2005 10:21 AM
carlton585
Apr 16, 2005 07:10 PM
