Blue smoke at high rpm , ls turbo???
the blue smoke at cold start is coming either from ur valve guides or valve stem seals and as for the smoke coming out at 6k is going through your rings for the compression test u can still have high comp. due to carbon build up on your pistons u should try a leak down test
aasarsak
Mar 28, 2009 05:34 PM
