is it worth putting gsr cams in a b16
Old Oct 27, 2004 | 02:24 PM
SLR ef9's Avatar
Default is it worth putting gsr cams in a b16
just wanted to know how much of a diff will it make to put gsr cams in a 1st gen b16. thanks for any info
Old Oct 27, 2004 | 02:44 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: is it worth putting gsr cams in a b16 (alphaprojectb16teg)
Minimal, CTR or ITRs would be a better choice.
Old Oct 27, 2004 | 05:00 PM
Seth21's Avatar
Default Re: is it worth putting gsr cams in a b16 (LSVTEC 91 Civic)
Absolutely if you are turbo if not go with some CTR's
Old Oct 27, 2004 | 05:43 PM
SLR ef9's Avatar
Default Re: is it worth putting gsr cams in a b16 (550whp)
do i need to upgrade the valvetrain with ctr's or itr's trying to build a budget car for weekend fun. money kinda tight just bought a new home
Old Oct 27, 2004 | 06:03 PM
mmuller's Avatar
Mad Scientist
1st gen cams are crap, upgrading to gsr cams is worth it and very cheap.
Old Oct 27, 2004 | 07:15 PM
SLR ef9's Avatar
Default Re: is it worth putting gsr cams in a b16 (mmuller)
thanx for the info keep it coming
Old Oct 29, 2004 | 10:04 AM
SLR ef9's Avatar
would i need to get cam gears for ctr/itr cams or can i use the stock b16 ones
Old Oct 29, 2004 | 10:22 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphaprojectb16teg &raquo;</TD></TR><TR><TD CLASS="quote">would i need to get cam gears for ctr/itr cams or can i use the stock b16 ones </TD></TR></TABLE>
you can use your stock ones
edit: ment to say that it is a worthy upgrade if your b16 has auto cams in it.
the profiling on the auto cams is so shitty cause it was ment to be for an auto tranny; power peaks a lot earlier in the powerband( and less power).
1st gen manual cams are NOT the same nor better than gsr ones; they are weaker. Intake cam is superior and on the exhaust mid lobe lift is the same, but the pri/sec. combo are bigger on the gsr.
Modified by mmuller at 2:25 AM 10/30/2004
Old Oct 29, 2004 | 11:21 AM
mattssi's Avatar
Here is the low down. If your 1st gen b16 was an automatic, then the cams are very mild due to the automatic gearing, if it was a manual, then the profile will be better than the gsr's. Most of the 1st gen b16's that i have seen were auto's. Either way, don't look for any gains from the butt dyno. If you are looking for measurable performance increase, go with ctr/itr.
longshot
Sep 26, 2008 09:32 AM
Import_lifestyle
13
Apr 23, 2006 09:41 PM
RACEPAK
Mar 23, 2006 07:48 AM
ShAAdiiiNG
18
Jan 10, 2003 05:18 PM
SuperCivic
19
Jun 28, 2002 07:09 PM
