OK so i got the CEL working now and here are the codes.....
Old Oct 27, 2004 | 02:20 PM
WickedWerx's Avatar
Default OK so i got the CEL working now and here are the codes.....
map sensor code
tps sensor code
vtec pressure switch code
CYP sensor code
so a good friend of mine from on here and local guy (brian saxon) says to flip flop the map and tps sensors and i did, reset the ecu and then fired it up. nothing now it wont even start at all!! saxon is away from aim on aol so i need some help!!!
is it not running now becuase of the CYP sensor or the VTEC sensor or should i flip the TPS and MAP back to the way they were? only thing is now the car wont start like i said but no more check codes for those 2 plugs now - HELPPPPPP
do i need a new dizzy also???
thanks
M
Old Oct 27, 2004 | 04:18 PM
WickedWerx's Avatar
Default Re: OK so i got the CEL working now and here are the codes..... (WickedWerx)
BUMP
ok now i got the VTEC issue code gone - still car has the MAP and TPS switched like brian said to but wont start but i am still getting the damn CYP Code - he sais i need a new distributor - let me know what you all think
thanks
M
Old Oct 27, 2004 | 06:12 PM
drdisco69's Avatar
With the cylinder sensor bad, the car won't start. Time for a new distributor.
Old Oct 28, 2004 | 05:34 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WickedWerx &raquo;</TD></TR><TR><TD CLASS="quote">... but i am still getting the damn CYP Code - he sais i need a new distributor...</TD></TR></TABLE>Hope you can find a wiring problem somewhere. The ECU can't tell the difference between a bad sensor vs. a broken/unplugged/shorted wire. Otherwise, you need a new distributor because I don't think they sell the sensor by itself.
Old Oct 28, 2004 | 07:02 PM
WickedWerx's Avatar
Default Re: OK so i got the CEL working now and here are the codes..... (JimBlake)
i redid some wiring to make sure it was ok and it is now for sure as far as i can tell - getting a new dizzy tomm so i guess that will help - any ideas why when i put the map and tps sensor where they SHOULD go the code flashes for both??? but when i flip them around the car wont start, and the codes go away - weird huh??????
hlep me on that one and please pray tomm or sat i get the new dizzy and further more that it works - thanks
M
WickedWerx's Avatar
bump
relentlesstech
Apr 10, 2014 06:22 PM
Preferio
Jul 6, 2005 08:56 AM
chrysler kid
Sep 28, 2004 07:24 PM
ILLICON3000
Aug 4, 2004 03:25 PM
kaj
Sep 27, 2003 09:36 AM
