Dashboard buzz at 2500 RPM??
Old Oct 27, 2004 | 01:37 PM
yangrou8's Avatar
Default Dashboard buzz at 2500 RPM??
ive had this buzz for two or three weeks now. it starts at 2500 rpm and sounds like it's comin from the dashboard on the left side. it's especially loud after i rev the engine and the engine is idling down (like between shifts when im off the gas). but it also happens when i slowly rev the engine above 2500 rpm. it's not a heatshield rattle - i already checked all those and it's also not the abs modulator i checked that too. anyone have any ideas/experience wit somethin like this?? help~
Old Oct 27, 2004 | 01:55 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: Dashboard buzz at 2500 RPM?? (yangrou8)
that 2500 rpm buzz you are hearing is from the heat shields underneath your car. That is the optimum RPM to creat sympathetic vibrations from the engine and exhaust to cause those to buzz. Trust me. Not your dash.
Old Oct 27, 2004 | 02:26 PM
yangrou8's Avatar
Default Re: Dashboard buzz at 2500 RPM?? (marsbike)
ive already taken off the heat shield for my cat and my header. ive had heat shield rattles before and this sounds nothing like it. it's more of a buzz and sounds like it's comin from the engine bay on the left side. anyone have any other ideas? TIA
Old Oct 27, 2004 | 02:32 PM
xprohx's Avatar
I think too much
There are heatshields all throughout your exhaust pipes...but that buzz could be anything.
Old Oct 27, 2004 | 04:48 PM
yangrou8's Avatar
Default Re: Dashboard buzz at 2500 RPM?? (xprohx)
anyone else?
Old Oct 27, 2004 | 04:54 PM
AlxSiR7's Avatar
do you have a short shifter? might be hitting the exhaust (i just had that problem).. my climate control thing rattles sometimes.. heh, my whole car is a rattle box.
Old Oct 27, 2004 | 06:08 PM
yangrou8's Avatar
Default Re: Dashboard buzz at 2500 RPM?? (AlxSiR7)
nah no short shifter. yeah my car's been rattlin a lot lately.. drove the car again tonight and it definitely feels like the buzz is comin from the dashboard/engine bay, not underneath the car... o well, looks like im just gonna have to get used to it.
GO SOX
Old Oct 29, 2004 | 08:37 AM
AlxSiR7's Avatar
isn't the heather core right behind the dash??.. just a thought
Old Oct 29, 2004 | 02:22 PM
AlxSiR7's Avatar
oh yea.. also might be a loose bearing in the tranny.. like the pilot bearing or the tob.. mine rattles and sounds like its coming from the dash..
Old Oct 29, 2004 | 06:10 PM
Medek's Avatar
what about the possibility of a small exhaust leak. maybe @ the cat.
Old Oct 29, 2004 | 06:55 PM
CRX_1.8T's Avatar
does it sound electrical?
Old Oct 30, 2004 | 04:39 AM
yangrou8's Avatar
Default Re: Dashboard buzz at 2500 RPM?? (CRX_1.8T)
how do u mean electrical?
it doesnt sound metal in nature. almost plastic on plastic??
Old Oct 30, 2004 | 11:58 PM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangrou8 &raquo;</TD></TR><TR><TD CLASS="quote">how do u mean electrical?
it doesnt sound metal in nature. almost plastic on plastic?? </TD></TR></TABLE>
my does that too sometimes..but that is when engine on cold temp..is it from drverside? like where the door and dash board meet?
Old Oct 31, 2004 | 01:46 AM
comteg396's Avatar
what kind of motor mount you have? i have energy suspension inserts all around and some stiff *** tranny mount. mine vibrate all over the dash because of it, but only at idle and when the car is hot. could also be that the engine is not running as smooth, so it transfer all the vibration to the chassis. check your motor mount
Old Oct 31, 2004 | 01:51 AM
Seven18T's Avatar
Default Re: Dashboard buzz at 2500 RPM?? (s0n1c b1u3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s0n1c b1u3 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of motor mount you have? i have energy suspension inserts all around and some stiff *** tranny mount. mine vibrate all over the dash because of it, but only at idle and when the car is hot. could also be that the engine is not running as smooth, so it transfer all the vibration to the chassis. check your motor mount</TD></TR></TABLE>
Yeah, check the mounts, I know it isn't a Honda but my GTI did the same thing after I put in poly mounts. Still rattles a bit now too
Old Oct 31, 2004 | 05:54 AM
yangrou8's Avatar
Default Re: Dashboard buzz at 2500 RPM?? (Seven18T)
stock motor mounts.
the buzzing doesnt change with temperature. it basically happens whenever i hit 2500 rpm and up. ive stuck my head in the engine bay and have touched eveything i can see wit my friend revving the engine. absolutely cannot locate it! sooo frustrating...
Old Oct 31, 2004 | 06:32 AM
00s2KkId's Avatar
touch everything on the inside of ur car also... my dash rattles and yea its annoying but i cant fix mine either.. mine rattles where the doors meet the dash.. check around places like that
Old Oct 31, 2004 | 12:39 PM
yangrou8's Avatar
Default Re: (96GSRkId)
hehe yeah ill go ahead and do that. looks like it's just somethin im gonna have to deal with.
Old Nov 2, 2004 | 10:52 PM
4DRmafia's Avatar
the best thing to do is get ear plugs
Old Nov 3, 2004 | 08:23 AM
99integraboy's Avatar
Default Re: (yangrou8)
Would your ABS make that sound around that RPM, or would that sound be all the time, just a suggestion
Old Nov 4, 2004 | 04:21 AM
yangrou8's Avatar
Default Re: (99integraboy)
i read a thread on this site stating that the abs modulator rattle is at 3500rpm and goes away after you add some brake fluid.
i just read that the IAT can also be causin a dashboard rattle. gonna mess around wit mine for a bit before work...........
any other suggestions are welcome. im completely stumped~
Old Nov 4, 2004 | 07:28 AM
siblue_gzer's Avatar
yea it could be low abs fluid, fill her up and see what happens
Old Nov 4, 2004 | 08:21 AM
yangrou8's Avatar
Default Re: (siblue_gzer)
already did that wit no change~~
Old Nov 4, 2004 | 11:32 AM
derrick2237's Avatar
I'd really check the engine mounts, those could make anything rattle.
Old Nov 4, 2004 | 01:07 PM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">does it sound electrical?</TD></TR></TABLE>
I have this problem with my wifes car and yes it sounds electrical, and I am sure this guy has the same problem!
