Any thoughts on the HKS F-Con on an f22 engine
Old Oct 27, 2004 | 01:33 PM
plkalra's Avatar
Default Any thoughts on the HKS F-Con on an f22 engine
Anyone have any experience with this on any car? Is this made for small amounts of boost? I may be wrong, but from my understanding, this unit is good for 6-7lbs of boost on stock injectors? Thanks in advance
I plan to use this on a
95 accord lx, trying to boost 6-7lbs using a RB25DET turbo, on an auto tranny.
Old Oct 27, 2004 | 01:35 PM
blundar's Avatar
are you trying to be different or do you have power / quality tuning as part of your goals too?
Old Oct 27, 2004 | 01:37 PM
plkalra's Avatar
i'm trying to boost my accord, in the range of 6-7lbs, I'm not trying to make a 300hp killer, but getting up to 170-180 would be nice.
I'm posting this question because I'm curious to know about this product, if i should use aftermarket injectors, or stock, or what.
Old Oct 27, 2004 | 01:40 PM
blundar's Avatar
if that is honestly your goal, a simple and cheap piggyback like a VAFC/SAFC or a SMC would work fine, when used in conjunction with a set of larger injectors. Tune it well, slightly retard timing on distributor, you'll be fine.
Old Oct 27, 2004 | 01:55 PM
plkalra's Avatar
thanks for the quick reply, and that is really my goal, I'm not trying to make some type of 300 or 400 hp monster. If i was going to do that, I would start with maybe doing a swap, and then turbo, or buying an sti or evo = )
I ask about the HKS F-CON because I picked it up for $26 from a guy who was using it on a HKS turbo kit he got from Japan (On his f22), he's moved onto a standalone, so I thought this would be perfect for me.
Djbigwill
Jul 12, 2013 04:44 AM
jamesfawcett
Apr 13, 2010 01:33 AM
goldex420
Apr 6, 2008 11:04 AM
jasony0630
Mar 16, 2008 05:38 PM
project civic
Sep 5, 2005 04:07 PM
