b16a problem
Old Oct 27, 2004 | 01:29 PM
highrevnef's Avatar
Default b16a problem
i was on the freeway on my way to work and when i accelerated from 70mph to 80mph my car just started to slow down and when i gas it it wouldnt accelerate so i pulled over and when i got to the end the car died. and now it wont start. ill turn the key but all u hear is the engine trying to start. wuts wrong with it?
Old Oct 27, 2004 | 01:36 PM
drdisco69's Avatar
Default Re: b16a problem (highrevnef)
I think it's broken.
Is that all you can tell us?
Old Oct 27, 2004 | 01:37 PM
highrevnef's Avatar
Default Re: b16a problem (drdisco69)
people tell me its the ignitor. but im not to sure.
Old Oct 27, 2004 | 01:38 PM
highrevnef's Avatar
i didnt hear anything snap or break my engine just started to coast. i would try to step on the gas but nothing.
Old Oct 27, 2004 | 01:43 PM
highrevnef's Avatar
wut happened was that i was on the freeway trying to pass up a car and as soon as i hit 80mph i felt my car jerk a little and from there it just started to deccelerate. the motor was still running but when i stepped on the gas pedal i got no response. the tow truck guy sprayed starter fluid in the manifol d thinking it would start but nothing he said it could be my fuel pump but i check it and it was fine. timing belts are on so its not that either. does anyone know?
Old Oct 27, 2004 | 01:45 PM
drdisco69's Avatar
Very well could be the ignitor. Pull a plug wire and check for spark. Keep in mind that if given time to cool, the ignitor may start working again. Another common problem is the coil.
Old Oct 27, 2004 | 02:31 PM
highrevnef's Avatar
is it wise of me to just go ahead and buy a whole new distributor????
Old Oct 27, 2004 | 02:55 PM
fourthgenhatchB17's Avatar
Have u even visually inpected the distributor? Take off the cap and see what u can see (rotor screw may have fallen out, melted components...etc)
I also read where u said the motor was still running when it started to coast. Could that be because it was still in gear and the force of the car moving was turning the motor over? If u didnt put the car in neutral, i bet thats what it was.
Old Nov 5, 2004 | 01:21 PM
RickJamesBitch's Avatar
Default Re: b16a problem (fourthgenhatchB17)
damn kirk i'll fix ur **** today
Old Nov 5, 2004 | 02:18 PM
B16 ED9's Avatar
Default Re: b16a problem (RickJamesBitch)
DAmn man, LMAo I guess who ever has a B16( including myself) has problem are the B16 giving up on us? there is an other post which the member has the same problem as yours man, so you may wanna read his post to
ttcheung97
Aug 24, 2020 06:31 AM
jasonlunaa
May 28, 2014 09:06 AM
mkeacura
Sep 17, 2013 06:17 AM
Ghost Shadow
Jan 13, 2008 08:00 AM
odishaw
Sep 25, 2004 04:45 PM
