CEL 17?
From: I told you to wait in the truck in Texas, United States
That is correct vehicle speed sensor..
that will not keep it from starting though...
Check fuse #14 under the dash labeled "alternator solenoid"
and also see: http://autorepair.about.com/cs...a.htm
for more ideas on trouble-shooting a "no-start" situation..
I have the same code and only thing wrong with mine is some dumb previous owner cut the speedo cable. From what I remember its either the cable isn't connected to the tranny/gauge cluster or the "mph" part is bad <where the speedo cable plugs in the back of the cluster>.
Code System
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 15 (15 flashes) Ignition output signal
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load.
when i had my Std hatch did a swap from 4spd to 5spd and i forgot to put back the speed cable and it gave me the same code so just check the tranny to see if its still in or check the back of the cluster also.
sirb18a
Sep 28, 2002 05:34 PM
