flapping noise from my left rear tire.
Old Oct 27, 2004 | 12:17 PM
SpeedMachine's Avatar
Default flapping noise from my left rear tire.
im getting an extremely annoying flapping noise from my rear left tire. it sound like plastic clicking or flapping on to something but i looked down there and there isnt ANYTHING. wtf can this possibly be someone help me out
Old Oct 27, 2004 | 12:29 PM
PrettyLude's Avatar
drive shaft
Old Oct 27, 2004 | 12:41 PM
drdisco69's Avatar
Default Re: (PrettyLude)
On a fwd car?
Could be a wheel bearing, or a shitty tire.
Old Oct 27, 2004 | 01:36 PM
have you had a problem like this before. did it sound like plastic flapping? its only coming from the left side and my g/f checked on the right and said she didnt hear anything. if it is the driveshaft you think it will need to be replaced or repaired?
Old Oct 27, 2004 | 06:12 PM
Default Re: (SpeedMachine)
bump
Old Oct 27, 2004 | 07:18 PM
Billy Blaze's Avatar
Default Re: flapping noise from my left rear tire. (SpeedMachine)
Check and see if your tires are cuped. Sometimes; depending on how bad it is, when your tires are cupped it can make a flaping sound. It sounds similar to a bad
bearing. Try rotating your tires and see if the noise changes; also make sure there isn't a plastic bag or something stuck on the lower control arm thats flapping in the wind.
Did somebody say check the drive shaft?
WOW....
Old Oct 27, 2004 | 07:55 PM
Default Re: flapping noise from my left rear tire. (Billy Blaze)
what exactly is cuped? i just had my tires rotated and balanced about 1 month ago unless they did a shitty job i dont think that it
Old Oct 27, 2004 | 08:06 PM
S10RALLYRACER's Avatar
Tire Pressure?
Tug on anything and everything around your back wheels and see if its loose
Junior1023
Oct 29, 2013 04:05 PM
EKsedan715
Nov 30, 2010 02:06 PM
codyb13
Apr 14, 2005 05:41 PM
johnqt3
13
Dec 12, 2004 08:26 AM
h22mark
Nov 1, 2003 05:25 PM
