ROTOR Removal, 98 Accord
Old Oct 27, 2004 | 09:57 AM
flowlrak's Avatar
Default ROTOR Removal, 98 Accord
I drilled out the 2 rusted-in-place screws on rotors and still can't free up the rotors original rotors. Do I need to pull the wheel from the axle? Is warpage a common problem with the Accord?
Old Oct 27, 2004 | 02:37 PM
CG2's Avatar
CG2
Default Re: ROTOR Removal, 98 Accord (flowlrak)
wow you have a 98 accord and the screws rusted? man there tough to loosen but all u need to do is spray wd40 and hit the rotor with a hammer to vibrate the screws loose inside and you can take your screw driver and loosen them up. anyways those are the only two screws holding the rotor on the axle....i just did my brakes last month
Old Oct 27, 2004 | 03:34 PM
f23accord's Avatar
Yea man just becareful not to beat it like a redheaded step child
Old Oct 27, 2004 | 05:46 PM
CG2's Avatar
CG2
Default Re: ROTOR Removal, 98 Accord (f23accord)
oh i was hitting it pretty hard i dont think you'll hurt it!!! cause that heat defenitley tightents them up.
Old Oct 27, 2004 | 07:37 PM
hawkmgc's Avatar
Default Re: ROTOR Removal, 98 Accord (CG2)
A realy pain system. Same as mine. it will come apart but may need a press to do so. good luck
Oh and try Liquid Wrench supper pen. it seems to eat out the rust and free it up in about 5 to 15 min.
SlowPokeEg
Jan 12, 2014 10:31 PM
sd619jef9
Suspension & Brakes
Sep 30, 2011 10:01 PM
accrd18
Mar 28, 2006 08:45 AM
accrd18
Mar 27, 2006 07:11 PM
dynamo
Oct 1, 2004 01:48 PM
