Emmisions failure, smelly exhaust, check engine code. You be the judge??!?
Old Dec 20, 2001 | 08:21 AM
Jason kiDD's Avatar
Default Emmisions failure, smelly exhaust, check engine code. You be the judge??!?
Okay I failed the Hydro Carbon part of the Emmsions test with a 487, with standard being around 220. Carbs were kinda high but were tollerable. What do you think my problem is guys, I know the car is running rich but why.
Setup: 91 Accord Hybrid. 98 JDM lude engine with stock injectors. P13 Jdm Ecu with limitors (sux). Ngk Plugs and wires. FPR set to 37psi.
Info: I get a O2 engine code whenever I go for long drives, running on an upgrade for an extended period, or drive over 100mph. Engine behaves real sluggish when the code is on. Exhaust smells like sulfur or gas all of the time.
Confusing Info: I get fairly good gas mileage still, the code disappears as soon as I restart the car again. (Off then On) Car drives normal after restart but is sluggish at anything under 3500 Rpms.
Where do you think my problem lies.???
Any comments suggestions would be greatly appreciated.
Old Dec 20, 2001 | 09:17 AM
EK-Cruiser's Avatar
New User
Default Re: Emmisions failure, smelly exhaust, check engine code. You be the judge??!? (Jason kiDD)
OT: Good game last night! 33 points, 8 assists, and 6 boards!
You guys spanked Minnesota in overtime! Plus your first place in the East! Go Nets!
Old Dec 20, 2001 | 09:23 AM
Jason kiDD's Avatar
Default Re: Emmisions failure, smelly exhaust, check engine code. You be the judge??!? (EKCruiser)
lol thanks but that isnt the exact info I was looking for.
Old Dec 20, 2001 | 10:43 AM
Spade's Avatar
Catalytic Converter!!!! They clog over time and stop cleaning the exhaust (smell) the clogging slows the exhaust flow (low power) and the O2 starts getting bad readings (crappy gas milage). You may have also burnt out the O2 sensor.
[Modified by Spade, 11:45 AM 12/20/2001]
Old Dec 20, 2001 | 11:00 AM
Jason kiDD's Avatar
Default Re: Emmisions failure, smelly exhaust, check engine code. You be the judge??!? (Spade)
Well that is the first for the Cat category. Most other people have said either the O2 Sensor or Temperature sensor. I do have the original CAT that came with the Accord from way back when, but I dont think you have though about all the symptoms. The car runs fine with anything above 4ooo Rpms. O2 sensor check engine light is not steady and would reset whenever the car is restarted. And I have a high HC count which means that too much gas is coming through the exhaust, which might null your clogged theory..??
Any comments welcome.
Old Dec 20, 2001 | 11:05 AM
Spade's Avatar
If you have the original CAT I am positive!!!! Replace the CAT. Do the O2 sensor as well, the high HC is from running rich, CAT's usually only last about three years!!!!
Old Dec 20, 2001 | 11:20 AM
Jason kiDD's Avatar
So should I look into a high/flow cat then since you would have me replace it as well as the O2 sensor.??
And since when do Cat only last 3 years??
Old Dec 20, 2001 | 11:24 AM
Spade's Avatar
Three years on a bad O2 sorry......n-e-way, sure you can look into a free flowing cat.....just make sure it isn't a racing cat. However, I don't think that they are worth the cost just get a new one, they are decent enough. You will not be able to tell by the Butt Dyno between a free flowing and a normal cat......they are only good on turbo or NOS engines.
Old Dec 20, 2001 | 11:37 AM
Jason kiDD's Avatar
Yeah well if anyone else can backup Spade's theories that would be nice. And thanks Spade for your insight on the matter..
Old Dec 20, 2001 | 11:59 AM
Spade's Avatar
Also, you might want to call a Smog repair shop and tell them that you have high HC's and they will tell you all the things that could be wrong.
Old Dec 20, 2001 | 12:05 PM
Jason kiDD's Avatar
Hmmn never heard of such a shop. Any references that you can point me to?
Old Dec 20, 2001 | 12:07 PM
Spade's Avatar
Yellowpages, Smog repair......
Old Dec 20, 2001 | 12:13 PM
Jason kiDD's Avatar
Coo.
LJS
Oct 3, 2017 01:14 PM
Cold Fyre
Jun 27, 2006 03:26 PM
lao_9
Apr 30, 2006 07:43 PM
jdmazm
Apr 21, 2005 07:58 PM
