Startup smoking
Old Oct 27, 2004 | 06:02 AM
db2integra's Avatar
Default Startup smoking
My new build has 100 miles on it but it still smokes every time I start it cold. It only smokes for about 4 seconds, and then the exhaust goes clean. What is causing this condition?
Old Oct 27, 2004 | 05:18 PM
db2integra's Avatar
Default Re: Startup smoking (db2integra)
bunnycivic's Avatar
If you only had the bottom end rebuilt, your problems could be in the head, most likely its the valve seals!
Old Oct 27, 2004 | 06:10 PM
drdisco69's Avatar
Default Re: Startup smoking (bunnycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bunnycivic &raquo;</TD></TR><TR><TD CLASS="quote">most likely its the valve seals!</TD></TR></TABLE>
Old Oct 28, 2004 | 05:08 AM
db2integra's Avatar
Default Re: Startup smoking (drdisco69)
Top end was rebuilt as well. I had a 3 angle done and the seals were replaced. My machinist said the valve guides were in good condition as well. Now I am starting to worry that maybe my ring/hone job wasn't good enough... I gapped the rings myself (first time doing it) and I had to use a ball hone over my machine shop's hone because the cylinders started getting minor spot rust before I put the pistons in. It still looked good when everything went together.
I am also hearing knock (I think) when I go into vtec on my stock obd-1 ecu, even though I have gone DOWN in compression (no FI yet). I have also gone up by 130 cc in displacement. This perplexes me.
Old Oct 31, 2004 | 05:39 PM
db2integra's Avatar
I am so fed up with cars right now. My newly rebuilt engine smokes like a chimney when you start it, it pings in vtec despite being 8.8:1 compression without forced induction, and it leaks oil like a sieve. I can't tell where the oil is coming from. I still have to put the lower timing belt cover on, but I am worried it will fill up with oil if I do so. I have to find a way to put the PCV breather hose on. The motor makes a loud clunk when I accelerate in reverse too hard, despite having a new front tranny mount.
My brakes were fine when I parked the car, but now the front rotors shake all over the place, and the rear pads are worn thin. The sunroof has rust spots all around it. My tent fell over and put scratches on the passenger door. I have no money left.
Old Oct 31, 2004 | 05:49 PM
B20luda's Avatar
**** man why dont u just blow the car up **** it...
Zaraki
18
Apr 21, 2009 04:04 PM
Hybrid96EK
May 18, 2008 05:52 PM
lsvtechatch92
Dec 23, 2007 02:02 PM
.I.Need.Money.
Jul 5, 2006 05:35 PM
huepowered
Apr 4, 2006 12:10 PM
