Need some B20vtec info
Old Oct 27, 2004 | 03:23 AM
CRAZYEG9's Avatar
Default Need some B20vtec info
Okay people, who has a B20vtec setup with stock block internals, what RPM do you rev 2, and how long did it last you. Give me details of your set up.
I want to do one but have no money to change the sleeves. The only thing I might be able to change is mabey the pistons, or if not that, the rod bolts, but if I find out I can do it with stock block interals I will. Give me some info on this.
Old Oct 28, 2004 | 07:20 AM
bluebird's Avatar
Default Re: Need some B20vtec info (CRAZYEG9)
Ive had mine for over 2 years and it happily revs to 8000
all stock internals
Old Oct 28, 2004 | 01:14 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Just keep it stock until you can afford to do it right.
Old Oct 28, 2004 | 05:29 PM
9SECQTR's Avatar
Default Re: (MugenDude)
word of advice try not to go above 8500rpm. the stock sleeves have problems holding up
Old Oct 28, 2004 | 05:31 PM
9SECQTR's Avatar
Default Re: (9SECQTR)
also, dont start building the motor until you have the $$ to do it all at once it will be a lot cheaper and a lot less of a hassle
Old Oct 28, 2004 | 09:00 PM
africanqueen's Avatar
Default Re: Need some B20vtec info (bluebird)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird &raquo;</TD></TR><TR><TD CLASS="quote">Ive had mine for over 2 years and it happily revs to 8000
all stock internals</TD></TR></TABLE>
I have had mine for 8 months. My ECU redline is set @ 8, so I am not gonna push it. + I shift @ 7800 anywayz. All stock internals. Hopefully not for 2 long
Old Nov 4, 2004 | 05:47 PM
BiTurboCiv's Avatar
Default Re: Need some B20vtec info (africanqueen)
i Shift about 8k also
Old Nov 5, 2004 | 07:14 AM
clint g's Avatar
Default Re: Need some B20vtec info (BiTurboCiv)
I didnt make the thread but thanx i needed answers as well
egfanatic
Sep 10, 2008 03:30 PM
vtec4max
Sep 30, 2006 02:57 PM
superg6819
May 31, 2006 03:54 PM
PAndADc2
10
Feb 3, 2005 08:23 PM
ophdehEEzY
12
Dec 30, 2003 11:37 AM
