will 15" wheel clear NSX calipers?
Old Oct 27, 2004 | 12:00 AM
volkdlr's Avatar
Default will 15" wheel clear NSX calipers?
Old Oct 27, 2004 | 12:33 AM
slammed_93_hatch's Avatar
Default Re: will 15" wheel clear NSX calipers? (volkdlr)
depends on what 15 inch wheel you are talking about
Old Oct 27, 2004 | 12:38 AM
volkdlr's Avatar
Default Re: will 15" wheel clear NSX calipers? (slammed_93_hatch)
I mean with the correct offset will 15" clear the NSX calipers? I don't remember if the early NSX came stock from the factory with 15" on the front or not.
Old Oct 27, 2004 | 12:51 AM
Dirk-EG's Avatar
Still depends on what brand rim. Some have thicker outer hoops, so they dont fit.. its mm fitment.. most will, some will not. Then you could shave a mm off the caliper, but I dont think you'd like that.
Old Oct 27, 2004 | 01:13 AM
IM ALL BOB's Avatar
I've seen 15inch ITR RIMS as well as 15 inch Mugen MF10s fit over the 11inch rotor/nsx caliper setup..good luck
SupremeDalek209
Suspension & Brakes
Mar 27, 2016 10:24 PM
CivSiClone_96
Suspension & Brakes
12
Feb 5, 2014 06:11 PM
B16B_coupe
Feb 25, 2009 09:05 AM
Sassafrass
Suspension & Brakes
Apr 21, 2008 05:21 AM
Rodney
Feb 22, 2005 11:02 AM
