will 15" wheel clear NSX calipers?
Re: will 15" wheel clear NSX calipers? (slammed_93_hatch)
I mean with the correct offset will 15" clear the NSX calipers? I don't remember if the early NSX came stock from the factory with 15" on the front or not.
Re: will 15" wheel clear NSX calipers? (volkdlr)
Still depends on what brand rim. Some have thicker outer hoops, so they dont fit.. its mm fitment.. most will, some will not. Then you could shave a mm off the caliper, but I dont think you'd like that.
I've seen 15inch ITR RIMS as well as 15 inch Mugen MF10s fit over the 11inch rotor/nsx caliper setup..good luck
SupremeDalek209
Suspension & Brakes
03-27-2016 10:24 PM
