60k maintenance questions....
i was looking over the maintenance package.. and most of them are all "inspect" and the only thing that i seem to have to worry about is the spark plugs, and brake fluid... any insight into this would be great. TIA
by the way i have a 00ex
Major Service Interval
Mileage: 30,000 - 60,000 - 90,000 - 120,000 - etc.
Engine oil and filter - replace
Fluid levels - top off all
Lube hinges, locks, latches, and hood cable
Front / Rear brakes - visual inspection
Transmission fluid - drain & refill
Lights - check operation
Clutch - adjust if applicable
Battery posts - inspect & clean
Fuel lines, tank, lines & connections - inspect
Spark plugs - replace (except platinum plugs)
Distributor cap & rotor - inspect
Tires - balance rear tires and rotate to front; adjust pressure & inspect tire wear pattern
Coolant system - Check level & test protection
Wiper blades - check operation & wear
Park brake - adjust & lube as needed
Front/Rear disc calipers & hoses
Air filter - inspect
Exhaust system - inspect
Suspension, struts & steering - inspect
Adjust valve clearance if applicable
Brake Fluid - replace and bleed system
Here is an archived thread I have saved on basic maintenance
https://honda-tech.com/zerothread?id=986411
io_burn
Aug 20, 2003 02:29 AM
