my tire is worn out
Old Oct 26, 2004 | 09:38 PM
AznMTboy's Avatar
Default my tire is worn out
i had a 02 accord and the front tires is pretty much bald, and it only 15k mileages, so is dat bad? or is it regular wear?
Can i go to michelin company n get a warrranty on it?
During the 15k i did bring the car to the dealer for maintain and usualy they rotate tires rite?
CG2's Avatar
CG2
Default Re: my tire is worn out (AznMTboy)
I syour car lowered?
Old Oct 26, 2004 | 09:40 PM
f23accord's Avatar
Damn man how are you driving your car? hope you dont think your rallying or somethin...granted the factory tires arent all that great but it should last alot longer than that
Old Oct 26, 2004 | 09:53 PM
AznMTboy's Avatar
Default Re: my tire is worn out (CG2)
it pretty much stock
all i hav in there is an intake and some underbody lights, and some hyper voltage n grounds wires.
Old Oct 26, 2004 | 09:55 PM
Charri's Avatar
Did you make sure your tires are properly inflated from time to time?
Old Oct 26, 2004 | 10:34 PM
Sex Cells's Avatar
Default Re: my tire is worn out (Charri)
first off id go check the tread wear on them (should be on the sidewall or something) either way thats highly abnormal for normal road tires but if there a low treadwear (softercompond) with some abuse which were all guilty of that might explain it, i would try going to the place you bought it first assuming you got it at a dealership, if not contact michelin.
Old Oct 26, 2004 | 11:24 PM
iam7head's Avatar
Default Re: my tire is worn out (Se7ens Travels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Se7ens Travels &raquo;</TD></TR><TR><TD CLASS="quote">first off id go check the tread wear on them (should be on the sidewall or something) either way thats highly abnormal for normal road tires but if there a low treadwear (softercompond) with some abuse which were all guilty of that might explain it, i would try going to the place you bought it first assuming you got it at a dealership, if not contact michelin.</TD></TR></TABLE>
those should be potenza bridgestone with 340TW, they last a freaken long time
and socal's road have nothing to do with it.
how is the tire worn out? the inner getting bald? the outer edge?
if you are not sure what kind of wear(normal or not) then post a clean picture of it
Old Oct 26, 2004 | 11:26 PM
philadd's Avatar
most likely, you're going to have to replace them on your own... my bet is that either your alignment is off (which you could actually determine by how the tire wore), or you drive like a madman. my original michelins lasted well past the average life and reached 75-80,000 miles.
miguey310
Mar 30, 2010 01:30 AM
OldAndInTheWay
Sep 15, 2008 04:35 AM
IsweatHONDA
Aug 22, 2006 09:13 AM
94civicx
Jun 17, 2002 02:43 PM
TypeR01-424
Nov 11, 2001 07:19 PM
