VAFC not resetting rev/throttle gauges???
Old Oct 26, 2004 | 07:33 PM
MakoE2's Avatar
Default VAFC not resetting rev/throttle gauges???
Hey i got a Apex'I VAFC and the problem is when its in the mode which give u two gauges of your rev/throttle it sticks at the highest rev/throttle i hit then it dosent go back down and the only time it changes is when i go passed the current high rev/throttle then it raises to the new rpm/thr and sticks at that
the only time it goes back to 0 is when i restart the car but it does the same thing. I tried intializiing but that didnt work either.
anyone ever have this problem?
heres a basic example of the problem
ok it reads RPM 400 and THROTTLE 0%
i drive a bit and i hit like 2000RPM and 16% throttle
then i let off and stop
however... the 2 gauges still read RPM 400 and 16% throttle
then when i drive again and say i hit 3000RPM and 30% throttle
ii stop and now it reads 3000RPM and 30% throttle
see the problem is, it sticks at the highest point it reaches then dosent reset itself...
One other thing as well is my VAFC reads like 400RPM at idle but the cluster reads 600RPM... which is the more accurate?
thanx for the help in advance!
Old Oct 26, 2004 | 07:37 PM
rev-speed's Avatar
ur in the peak hold mode
did u try hitting next in that screen
Old Oct 26, 2004 | 07:38 PM
MakoE2's Avatar
Default Re: (4cylinder)
yeah when i hit next it just goes to the other view options... liek the bar graph and tthen the number display then the 2 gauge pod thing
how do i get out of the hold peak mode?
Old Oct 26, 2004 | 08:05 PM
ekgcool's Avatar
Default Re: VAFC not resetting rev/throttle gauges??? (MakoE2)
If its a VAFC 1, push the DOWN button. If its the VAFC 2 push the center **** down. That should take care of it.
CRXSIR1
Sep 5, 2006 02:47 PM
tianporn
Mar 26, 2005 12:30 PM
xx dc2teg xx
Aug 31, 2004 12:19 PM
cjames235
Dec 11, 2003 06:06 PM
cjames235
Dec 11, 2003 12:39 PM
