Please Help-Car WILL NOT RUN RIGHT
The story.
did a z6 swap in my 90 crx dx...ran good for a while with hacked up wiring, bought an entire plug and play engine harness to fix some things up, in the mean time I changed out the distributor and did a couple other things becasue it wasnt starting...i got it started but it ran like crap, feels like its running in 2 cyls. Im getting fire from all 4, the map sensor is good but its flooding with fuel. floods so much that when I give it gas it barely stays alive. Can someone please help me, car will not throw any flashes so I cant read any codes but the cel is on. Its been way to long for a z6 swap to not work right.
what has me confused is that this motor was running perfect in the previous crx, and I had it running fine in my car..so I dont thinbk I could just fry injectors, I could be wrong, but I dont think so.
do you know what 3 cylinders firing sounds like?
check your injector wiring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicedREX »</TD></TR><TR><TD CLASS="quote">p28, ive heard that if a motor sits for a while I could have a stuck injector...it sat for max maybe about a month without being ran...?</TD></TR></TABLE>
nnah my crx sits every winter (6mo) and doesnt do anything to it.
this "plug and play" harness.. what is it, give more details.. engine harness? or obd0-obd1 ecu adapter harness?
it was a complete engine harness, to plug into all the sensors and parts of the z6, and to plug into the stock connectors coming from the firewall. I ALSO have a conversion harness, obd0-obd1 for the p28. The engine harness was created with the conversion harness so there werent any problems.
cj90si
Nov 15, 2012 01:10 PM
cticknor666
11
Jul 21, 2009 05:49 AM
dusterbd13
Jul 18, 2009 12:23 PM
sohcdestruction
10
Oct 4, 2007 06:05 PM
