need help with engine code please 2000 civic ex
Old Oct 26, 2004 | 07:09 PM
drastikchangez's Avatar
Default need help with engine code please 2000 civic ex
P0131 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage am not sure where its located or even where to start if anyone knows the location and how to change it your help would be greatly appreciated.
Old Oct 26, 2004 | 07:21 PM
drdisco69's Avatar
Default Re: need help with engine code please 2000 civic ex (drastikchangez)
If you have less than 80,000 miles, take it to the dealer and have them check it out. Those civics have a common problem of the exhaust manifold cracking, and causing O2 related check engine lights. For that car, new exhaust manifold = free if you have less than 80,000 miles, as the catalytic convertor is built in to it.
Old Oct 26, 2004 | 08:35 PM
ekgcool's Avatar
Default Re: need help with engine code please 2000 civic ex (drdisco69)
LX Civics have that problem, not EX. My guess is the O2 is taking a dump, or there is a problem in the wiring.
Old Oct 26, 2004 | 08:36 PM
ekgcool's Avatar
Default Re: need help with engine code please 2000 civic ex (tekracer)
Oh, BTW the Primary O2, is on the exhaust manifold, near the head. Its the first O2, as the second is after the cat.
Old Oct 27, 2004 | 12:55 AM
thanks for everyones help
Matt Ruiz
12
Jan 29, 2015 01:09 PM
chris0628
Mar 27, 2010 05:32 PM
redintex
Nov 27, 2006 12:32 PM
Mike813
Mar 17, 2005 03:49 PM
drastikchangez
Oct 26, 2004 08:13 PM
